Cannot connect to serviio server AT STARTUP
Jayme65
Post Mon May 06, 2013 4:25 pm
When my PC starts, I get this alert window:
"Cannot connect to serviio server, it does not seem to be running. Exiting"
But once the PC completes its startup procedure I can see that I can access the Serviio server!
I've tried to set the Serviio service to "Start Delayed" to see if that message dissapears...but NO!
What should I please do to have this message stop appearing?
Thanks!
slyguy42o
Post Mon May 06, 2013 4:42 pm
Re: Cannot connect to serviio server AT STARTUP
the problem is that the console is trying to start before the service has fired up. Setting to delayed is just going to increase the issue.
You can resolve this by taking the serviio console out of your startup then firing it off as needed later manually.. the console is not required for serviio to run, just the service.
A side thought on this.. if you want the console to fire up at system start you will need to find a way to delay it to give the serviio service enough time to finish starting up.
Users browsing this forum: Baidu [Spider] and 33 guests
