MediaBrowser how to exit playing a video
stevedh
Post Thu May 23, 2013 3:20 pm
Hi, I have had a search and this may seem like a silly question, but when I play a movie in mediabrowser, I can't find any way to exit it and go back to the menu.
all I seem to be able to do is pause it, or display it full screen.
this is using serviio 1.2.1 installed on a windows 7 pc
thanks for any help
Steve
Post Thu May 23, 2013 5:12 pm
Re: MediaBrowser how to exit playing a video
There is a X button in the top right corner of the playback window.
stevedh
Post Fri May 24, 2013 9:03 am
ahh thanks... I see it now thanks :)
is there a way of changing the default skin as the grey X on a black backround is almost invisible on my crappy monitor.
also while I'm here how do you enable subtitles in the MediaBrowser?
thanks
Steve
Post Fri May 24, 2013 1:55 pm
there should be a CC button in the player when subtitles are available
stevedh
Post Mon May 27, 2013 8:59 am
I'd typed en instead of eng for the language so it wasn't appearing... so my fault again :)
Users browsing this forum: Google [Bot] and 41 guests
