Issue found on file discovery
jaimefcb
Post Sun May 26, 2013 9:21 pm
Hello, Im new here and I started as user of Serviio with latest 1.2.1
I have a folder with movies and some of them were not listed, I tried to change different values, file name, I unistalled and installed servioo, and finally problem was solved changing a value on log4j.xml file... :S
I take al look on log file and I found the 'unknown file type' under ffmpeg -i command... on non listed movies
I've been reading on this forum and Zip pointed to change this option on log4j: <param name="Threshold" value="TRACE"/>
I do not why but after I changed that everything was detected... Probably doesn't make any sense but I hope someone can use it for his own...
In other hand, Serviio is awesome, I got my Pro yesterday! Thanks for your work guys! :)
Post Tue May 28, 2013 11:29 am
Re: Issue found on file discovery
That does sound weird :-)
jaimefcb
Post Tue May 28, 2013 9:58 pm
Yes totally but I swear that I didn´t change any other thing... I had the file discovery problem from the begining and even I uninstalled and installed serviio. I will try to check if I can repeat the thing and I wil to provide to you a log for investigation. Regards!
