Ubuntu 12.04 | Serviio 1.2.1 | No connection
Ramin
Post Tue May 28, 2013 12:14 pm
Good day all,
First of all I want to thank ZIP for developing this fantastic tool and you for making time to read my question.
I downloaded the Linux tar.gz-file from serviio.org.
I untarred the file in ~/Serviio. All necessarily applications are installed.
I added ~/Serviio/serviio.sh to the start-up-programs. After a restart serviio is started (ps aux | grep serviio).
I do not see any errors in the log files.
My Samsung TV, my Android devices (AnDLNA) do not register the serviio server.
My TV is cabled with my router. For sure the desktop and TV are in the same network.
If I open Serviio console, I see that my Samsung TV has been registered. I changed the profile to Samsung C/D/E, but this does not help. The status is 'unknown'.
In the console the network settings are set as IP-address (not automatically detected).
Does anyone know what could be wrong.
I know this is very little information, but I really have no clue.
The only thing I can think of is a chmod/chown issue. I untarred the files as user and root wants access. On the other hand, root is root :)
I attached the logfiles (serviio and derby (derby is the 'webserver', right?)). The logfiles below are created after the following:
I stopped the service (sudo stop serviio)
I deleted the log files (rm ~/Serviio/log/*)
I started serviio (sudo start serviio)
The log files atached is the result.
Thank you in advance,
Ramin
derby.log
(621 Bytes) Downloaded 434 times
(12.84 KiB) Downloaded 460 times
Post Tue May 28, 2013 12:33 pm
Re: Ubuntu 12.04 | Serviio 1.2.1 | No connection
Is 172.16.0.10 your IP address?
If not, you have to bind it to the right one in the console.
Also make sure you have your firewall set up right, as per the FAQ.
Ramin
Post Tue May 28, 2013 11:27 pm
Thank you for your reply.
172.16.0.10 is my static IP.
I investigated the port settings. I have a Linksys router with DD WRT installed on it. Internet says that by default all ports are open. Please, share if you have other information.
The strange thing is that on the laptop where Serviio is running netstat gives me the following output:
user@user:~$ netstat -an | grep LISTEN
[b]tcp        0      0 0.0.0.0:8895            0.0.0.0:*               LISTEN     [/b]
tcp        0      0 0.0.0.0:23423           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:23424           0.0.0.0:*               LISTEN
tcp        0      0 127.0.1.1:44331         0.0.0.0:*               LISTEN
tcp        0      0 127.0.1.1:44332         0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:5940          0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN
tcp6       0      0 :::3689                 :::*                    LISTEN
tcp6       0      0 ::1:631                 :::*                    LISTEN
[b]unix  2      [ ACC ]     STREAM     LISTENING     8895     /tmp/.X11-unix/X0[/b]
unix  2      [ ACC ]     STREAM     LISTENING     372711   /tmp/82706559B627945AD7D6957FA50E595101B54053.25.0.1364.160_service_ipc
unix  2      [ ACC ]     STREAM     LISTENING     14163    /tmp/keyring-t5dxRr/control
unix  2      [ ACC ]     STREAM     LISTENING     535918   /tmp/OSL_PIPE_1000_SingleOfficeIPC_ab5add7cd32d27b7615d3db6bad6fedd
unix  2      [ ACC ]     STREAM     LISTENING     14231    /tmp/ssh-kKqIqWPS1938/agent.1938
unix  2      [ ACC ]     STREAM     LISTENING     13108    /tmp/.ICE-unix/1938
unix  2      [ ACC ]     STREAM     LISTENING     14260    /tmp/keyring-t5dxRr/ssh
unix  2      [ ACC ]     STREAM     LISTENING     15548    /tmp/keyring-t5dxRr/pkcs11
unix  2      [ ACC ]     STREAM     LISTENING     8723     /var/run/dbus/system_bus_socket
unix  2      [ ACC ]     STREAM     LISTENING     476709   /var/run/cups/cups.sock
unix  2      [ ACC ]     STREAM     LISTENING     1261     @/com/ubuntu/upstart
unix  2      [ ACC ]     SEQPACKET  LISTENING     1337     /run/udev/control
unix  2      [ ACC ]     STREAM     LISTENING     10063    /var/run/acpid.socket
unix  2      [ ACC ]     STREAM     LISTENING     7838     @/org/bluez/audio
unix  2      [ ACC ]     STREAM     LISTENING     8894     @/tmp/.X11-unix/X0
unix  2      [ ACC ]     STREAM     LISTENING     8808     /var/run/sdp
unix  2      [ ACC ]     STREAM     LISTENING     7809     /var/run/avahi-daemon/socket
unix  2      [ ACC ]     STREAM     LISTENING     13103    @/tmp/dbus-ZRhViiU3Ik
unix  2      [ ACC ]     STREAM     LISTENING     15549    /tmp/keyring-t5dxRr/gpg
unix  2      [ ACC ]     STREAM     LISTENING     14677    /home/ramin/.pulse/adaa1c56825cf10268657f0b00000009-runtime/native
unix  2      [ ACC ]     STREAM     LISTENING     16443    socket
unix  2      [ ACC ]     STREAM     LISTENING     20357    /tmp/.org.chromium.Chromium.dAdVCr/SingletonSocket
unix  2      [ ACC ]     STREAM     LISTENING     7916     /var/run/autokey-daemon
unix  2      [ ACC ]     STREAM     LISTENING     13107    @/tmp/.ICE-unix/1938
user@user:~$ netstat -au
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
udp        0      0 *:mdns                  *:*
udp        0      0 *:45826                 *:*
[b]udp        0      0 *:1900                  *:*                                [/b]
udp        0      0 localhost:domain        *:*
udp6       0      0 [::]:mdns               [::]:*
udp6       0      0 [::]:52245              [::]:*
My daughter is now watching a movie and she asked me to get rid of 'that'. I looked to my TV and saw that Serviio was detected. But... I took my Android device and started AnDLNA and ServiiDroid. No server could be found. I tested if Serviio was still connected to my TV. After 'waiting' for a while the message came that Serviio was disconnected.
Any suggestions?
Ramin
Post Wed May 29, 2013 1:47 pm
Static IP you mean static LAN IP, not public IP, right? If yes, then fine.
Might be some setting on the router, like IGMP. Try to search the forum.
