Serviio can't not redraw own window
laryk
Post Tue Jun 04, 2013 2:00 pm
I have added a folder with some subfolders and ~4K files to the Shared Folders list. After this, Serviio can't re-draw the Library tab.
I see a previous tab controls instead of the Library ones. Other software tab's are redrawing without any problems.
So currently I can't add/remove my folders.
My OS is Windows 8 64bit. Exit/launch Serviio and reboot PC did not help.
Thank you.
Post Tue Jun 04, 2013 4:35 pm
Re: Serviio can't not redraw own window
You might try to reinstall your Java
laryk
Post Tue Jun 04, 2013 7:26 pm
zip wrote:You might try to reinstall your Java
That fix the problem.
Thanks for a good piece of software!
Users browsing this forum: Google [Bot] and 44 guests
