XBOX 360 not connecting to Serviio?
mackmoney3000
Post Fri Jun 14, 2013 1:58 am
Thanks for reading my question.
I have an Xbox 360 sharing a network with my debian linux machine running Serviio.
The Xbox 360 can see the Serviio share I created in its video player, but cannot seem to "connect" - the connection from the Xbox always times out and spits out the "are you behind a firewall?" text on the xbox. The serviio console has no trouble seeing the Xbox either.
Frustrating is I set this up once before, redid my linux install, and now it no longer works.
Has anyone seen this or have any idea what to do to sort it? Thank you.
mackmoney3000
Post Fri Jun 14, 2013 11:39 am
Re: XBOX 360 not connecting to Serviio?
I sorted this on my own :D
After taking a look at /var/log/serviio/serviio.log (which I should have done to begin with!), I noticed serviio was complaining about missing the "dcraw" package. I installed it, restarted serviio, and now the xbox connects.
Thank you...
