WD TV Live, subtitles dont work
tcviper
Post Mon Aug 06, 2012 11:52 am
The main website states that WD TV Live devices should work with subtitles but it doesnt.
I tried to play MKV files that have a same name .SRT file with it and when playing through serviio 1.0 the WD TV Live says no subtitles, it seems only embedded subtitles work?
When adding the network drive directly in the WD TV, subtitles play fine.
Any idea?
Sony KDL-55W905A | KDL-32EX521 | 32W5500 | STR-DN1040 | MacMini | Synology 1511+ | Network Cisco
Post Mon Aug 06, 2012 12:44 pm
Re: WD TV Live, subtitles dont work
try to search the forum. It might only support subs for certain files. Also make sure you have WDTV profile selected.
tcviper
Post Mon Aug 06, 2012 12:47 pm
lol, i always thought it would do that by itself but you are right, wrong profile was selected (it was set to generic!).
tcviper
Post Mon Aug 06, 2012 12:50 pm
That did not solve it though, according to your website: WDTV Live (supports subtitles) and the description says .SRT, but it keeps saying subtitles: off.
Post Mon Aug 06, 2012 1:31 pm
RS_Sing
Post Sun Jun 23, 2013 4:37 am
There's an easy work-around for WD TV Live not displaying external subtitles with mkv video files.
Basically you re-mux the mkv and make the external .srt file part of the mkv file.
A good tool for doing this is mkvmerge. It's fast and easy to use. Not sure if it's available for Windows or Mac, but I use it on Linux and it works really well.
lidow
Post Thu Jun 27, 2013 8:01 pm
You can always set hardsub for mkv container for example. With Serviio 1.2.1 the subtitiles will be burned into the movie.
This is what I add in my profile.xml to enable hardsub:
 <Profile id="14" name="WDTV Live" extendsProfileId="1">
        <Subtitles>
               <SoftSubs mime-type="text/srt" />
               <HardSubs>
                     <RequiredFor container="matroska" />
              </HardSubs>
       </Subtitles>
