Java-Problems
Jue2r
Post Fri Jul 05, 2013 7:34 am
Java-Problems
During installing serviio free the first time, the installation process downloaded Java 7 update 5.
I had already installed Java 7 update 25 (x64).
After updateing Java again to update 25, serviio does not start anymore and an error occurs when rebooting.
How can I have everytime the last Java update and serviio running?
Serviio is a very good and fast DLNA software!
I don't want to miss!
Thanks for any hints!
Hardware: i7-2600k, 8GB Ram, Samsung SSD 256GB, Asus P8Z68 Deluxe
OS: W7 prof. x64
Post Tue Jul 09, 2013 6:39 am
Re: Java-Problems
Try removing all old versions of Java from your machine using the java removal tool (http://www.java.com/en/download/uninstallapplet.jsp). Once done test again - you may need to uninstall Java and then re-install.
Users browsing this forum: Google [Bot] and 77 guests
