RTMP Help
k87
Post Sun Jul 14, 2013 1:05 am
RTMP Help
I have been trying for the past few hours to get an rtmp stream to work with serviio, but I cannot get it to work. I am new to this and have been trying to wrap my head around how it works. I am using rtmpsrv.exe to get the data I need but I am not sure if I am entering everything correctly. Below is the data I got with rtmpsrv.exe for a stream on Vipbox.
rtmpdump -r "rtmp://edge.isearch.to/edge" -a "edge" -f "WIN 11,7,700,224" -W "ht
tp://player.ilive.to/player_ilive_embed.swf" -p "http://www.ilive.to/embedplayer
.php?width=640&height=480&channel=%2036674&width=650&height=450&autoplay=true&au
toplay=false" -y "z28ie9oqoku4qoy" -o z28ie9oqoku4qoy.flv
I have been trying to enter it into serviio like this:
rtmp://edge.isearch.to/edge app=edge playpath=z28ie9oqoku4qoy swfUrl=ht
tp://player.ilive.to/player_ilive_embed.swf swfvfy=1 live=1
but it does not seem to be working for me. Can someone help me out and let me know if I am doing it correctly. I really appreciate it.
Post Sun Jul 14, 2013 3:44 am
Re: RTMP Help
ffplay -i "rtmp://edge.isearch.to/edge app=edge playpath=z28ie9oqoku4qoy swfUrl=http://player.ilive.to/player_ilive_embed.swf pageurl=http://www.ilive.to/embedplayer.php swfvfy=1 live=1"
but why not use the ilive plugin?
k87
Post Sun Jul 14, 2013 6:08 am
Re: RTMP Help
Like I said, I am new to all of this. So would you recommend the Ilive plugin? I will have to go ahead add that to the plugin folder. So after I add the plugin to the folder do I just add url of the page where the stream is, similar to the twitch/justin.tv plugin?
Post Sun Jul 14, 2013 2:53 pm
Re: RTMP Help
Read the plugin instructions.
k87
Post Sun Jul 14, 2013 4:39 pm
Re: RTMP Help
I got it working, thanks for your help, and pointing me in the right direction.
k87
Post Mon Jul 15, 2013 1:16 am
Re: RTMP Help
I have run into another problem. I am trying to make an nba tv stream work with serviio since most of the sports live feed sites are no longer compatible with serviio at the moment. I have got one working but the quality of the stream is just so so. I would like to use the stream at this link http://www.stream2watch.me/live-tv/nba-tv-live-stream, but I am unable to find the information I need in order to add it to serviio. I tried using URLSnooper and rtmpsrv.exe without any success.
