How connect to remote machine?
ryyyiu
Post Wed Jul 24, 2013 9:34 pm
Hello, im trying to tutorial how to set up serviio for nsa 325 nas server, and stopped on point 7, how to connect to nas server, i don't know what is going on here..
====== 7) Manage Serviio and add media ======
Install the Serviio console of your choice (e.g. Windows Serviio package and select console only) and configure to remotely manage the NAS instance of Serviio.
To add a folder you need to use the relevant linux path on the server. e.g. for a single mirrored pair of disks that would be:-
/i-data/md0/<SHARE NAME>/<MEDIA FOLDER>
e.g.
I wouldn't recommend the NAS is allowed to generate thumbnails as it drives the CPU quite hard. Initial loading of the library will also work Java and ffmpeg hard until fully scanned
And also a question, is it normal that serviio uses 80% of cpu when watching a movie through dlna????
Post Sat Jul 27, 2013 12:11 pm
Re: How connect to remote machine?
you have to either install Windows package on a windows box with the Console only option, or other console application (like ServiioDroid) to be able to configure your headless serviio server
Users browsing this forum: No registered users and 65 guests
