Can't login and connectivity status wrong
secretdk
Post Thu Aug 01, 2013 4:57 pm
I just started installing and using this awsome program. So far set up my libraries and port forwarded.
I'm able to acces the website remotely.
The problems i'm having are;
1). Not being able to login locally or remotely. It both returns the message that i am entering the wrong password (i've already updated the password a couple of times)
2). The connectivity status button retusn me with a wrong cross, saying its not able to connect. I did forward my ports correctly as im able to acces it.
My firewall is off and with my anti virus disabled i'm still having the same problem.
Is it perhaps happening because my libraries are still being updated?
Any help on this would be great.
secretdk
Post Thu Aug 01, 2013 9:14 pm
Re: Can't login and connectivity status wrong
Nobody with any idea's?
EDIT:
Nevermind, i got it somehow working by restarting a couple of times and changing some info.
Connectivty status still says it doesn't work, but it does so far.
Only question im having;
Isn't it possible to browse through the folder structure i've set on my server instead of doing it through the regular sub-categories?
It doesn't seem to order all the series and movies right.
EDIT 2:
Nevermind already found it. This is realllyyyyy great. I love it.
Going to buy the pro version.
