Remote access help needed
FatalOne
Post Mon Jul 29, 2013 1:59 am
First off, I wanna give thanks to an awesome piece of software.
I built a headless server running WHS 2011, I've had Serviio Pro running on this little over a year now, and it is rock solid, have no issues accept for streaming content remotely...
The remote access is set up correctly, I can access my content via media browser and serviigo, I can even stream it at a decent quality due to my 2 Mbps up bandwidth, but the kicker is after about 5 to 10 minutes of flawless streaming... It just stops... Serviio is still running, ffmpeg is still transcoding... It just stops streaming, it stops passing data, network utilization drops to zero... During this time, I can still access and stream content locally, everything works as it should except for remote streaming...
I have no other network issues with the server, I can access whs 2011 remotely, I have xbmc clients that stream the same content flawlessly...
This is an always on box with no power savings or sleep utilities active...
Any ideas or suggestions would be greatly appreciated
Thanks!
Post Mon Jul 29, 2013 3:16 am
Re: Remote access help needed
Do you forward port 23424 in your router or use UPNP to have Serviio do it automatically? If the latter, check that the automatic port forward is not dropping out (you may want to test by putting in a manual, permanent forward of TCP port 23424).
Also do a detailed log and see if that sheds any light on what is happening.
FatalOne
Post Mon Jul 29, 2013 8:38 pm
Yes, I forward my ports manually.
I turned on debugging, did a fresh restart of the system, and accessed serviio remotely with serviigo, streamed content till it dropped out. I opened up the log and was reviewing it, nothing really popped out at me, except at the end.
2013-07-29 16:28:11,168 DEBUG [WebServer] I/O error: Connection reset
Could this be the culprit... does this shed any light on where to go next?
Thank you again!
Post Mon Jul 29, 2013 9:59 pm
Does this happen also if you chose the lowest quality for remote streaming?
FatalOne
Post Mon Jul 29, 2013 10:06 pm
That instance was using the lowest quality...
*EDIT* A side note, even when using lowest quality, my phone peaks up to 1.5 Mbps....
FatalOne
Post Wed Jul 31, 2013 11:18 pm
Nobody has any ideas or suggestions, I would really like to get this resolved. I'm not really sure where to go from here..
Thanks in advance! :D
Post Thu Aug 01, 2013 7:55 pm
so you're seeing the same with MB and ServiiGo right?
FatalOne
Post Thu Aug 01, 2013 8:57 pm
I just verified, that is correct, this happens both with servigo and MB...
Post Fri Aug 02, 2013 3:56 pm
DO you have any firewall or similar? Not sure if something might be cutting any unknown connection after a while.
Users browsing this forum: No registered users and 64 guests
