Online Sources - How can I load via CLI vs the GUI
tstrike
Post Fri Aug 02, 2013 2:19 am
Love the GUI, but I wish I could manipulate with the Online Sources instead of click, click, click.....
Help? Is there a file I can update or add online sources?
Post Fri Aug 02, 2013 3:54 pm
Re: Online Sources - How can I load via CLI vs the GUI
You could do it via REST API. 1.3 also comes with a concept of ServiioLinks :serviiolink: (a URL that you can just click on and it'll pre-fill everything in the console) as well as backup/restore online content to files (so you can create a file and import them that way)
tstrike
Post Fri Aug 02, 2013 6:43 pm
zip wrote:You could do it via REST API. 1.3 also comes with a concept of ServiioLinks :serviiolink: (a URL that you can just click on and it'll pre-fill everything in the console) as well as backup/restore online content to files (so you can create a file and import them that way)
oooooo when does 1.3 release? is there an RC I can play with?
Post Fri Aug 02, 2013 9:51 pm
next week
Users browsing this forum: No registered users and 54 guests
