Solved: Serviio 1.3 / Mediabrowser don't play mp3 with IOS
Streamer
Post Fri Aug 09, 2013 9:26 pm
Hello my name is Danny. I’m from Switzerland.
Serviio 1.3 Pro works fine. I can play now the Movies on my IPad (MediaBrowser) with the Safari Browser. Unfortunately, I can’t start the Mp3 Files on my IPad/IPhone(MediaBrowser).
The Audio Player no longer pops up when selecting a file. I can drag a file to the playlist, but also when starting from there the player is not starting. I tried Google Chrome, Safari, etc.
Status: Download latest Release 1.3 (other Topic, Bug IE -MP3 Problem) reinstalled Serviio 1.3, rebooted PC, cleared CacheBrowser (IPad)
-> Result: Klicking mp3-Files, the player is not starting!! Video-Files still working :o
Tks a lot for help/feedback (sorry for my bad englisch)
Danny
Post Fri Aug 09, 2013 9:48 pm
Re: Problem Serviio 1.3 / Mediabrowser don't play mp3 with I
Are you sure the newly downloaded version is the correct file size? Its possible the downloaded file itself was cached.
Streamer
Post Fri Aug 09, 2013 11:42 pm
Hi Zip,
yes i'm sure - After reinstall the problem with mp3 Files in the IE9 was solved.
Danny
Post Fri Aug 09, 2013 11:44 pm
So the popup window doesn't show on iPad? The same way it was happening on IE? But IE works now... in that case it should work everywhere.
It works on my iPad 4.
Streamer
Post Sat Aug 10, 2013 5:30 am
Solved: Problem Serviio 1.3 / Mediabrowser don't play mp3 wi
Thank you - now the Mediabrowser (Audio and Video-Files) works great on my IPad.
Final Solution: download 1.3 again, reinstall Serviio, reboot pc and finally reboot IOS devices Ipad and Iphonene :!:
Thanks for your Support.
Danny
Users browsing this forum: Baidu [Spider] and 33 guests
