WD Live TV Plus Subtitles Issue with 1.3 version
ivan787
Post Tue Aug 13, 2013 11:09 pm
Re: WD Live TV Plus Subtitles Issue with 1.3 version
Just to let you know i tried all possibilities on the console for the subtitles and they are not being taken, when i disable any kind of subtitles on the console the embebed stays on the WDTV still doesnt show the srt file as option
ivan787
Post Tue Aug 13, 2013 11:35 pm
Also tried this option
viewtopic.php?f=5&t=6970
but when i add the line serviio server wont run. it will quit automatically
ivan787
Post Wed Aug 14, 2013 5:50 am
beside the possible solution you can offer me, is there any way to make mkv to be transcoded with the subtitles? i know WDTV supports MKV so what should i change to make it transcode
Post Wed Aug 14, 2013 8:52 am
Ok, I will make a change for 1.3.1 to revert to the behaviour in 1.2.1.
You cannot transcode to MKV.
ivan787
Post Sun Aug 18, 2013 7:42 pm
Hey Zip thanks for the support but seems that serviio is not for me :´( . I made a mistake, after some research i found out that the srt files were not even playing on 1.2.1 they were spanish subtitles embebed on the movie, after the research found out next.
WD TV Live doesnt support srt files over DLNA... so it wont work no matter what i think.
My Samsung TV or Bluray doest support Embebed subtitles only SRT
So unfortunately to have both i will need to go back as i was having my hard drive connected directly to the WD TV Live. i research and seems that neither samsung 2013 tvs play embebed subtitles so i will need to check what other options i have, i will keep serviio for music and images but unfortunately for movies it wont work as i want.
Thanks for your support.
Post Sun Aug 18, 2013 10:19 pm
AFAIK WDTV live does support external srt files. Not sure if they broke it in some recent firmware.
ivan787
Post Mon Aug 19, 2013 12:59 am
it does support it when the mkv and srt file are attached as hard drive but not via dlna, i have heard this from different forums and also tested a couple of more Media servers like serviio on none of them worked.
Hard drive/usb/network share works fine and srt is readable but no over DLNA
http://community.wd.com/t5/WD-TV-Live-D ... 660#M32380
http://www.wildmediaserver.com/forum/vi ... f=12&t=137
On Plex forums they are saying the same :(
Previous
