Additional library-related log filters needed
jen142
Post Sat Aug 24, 2013 11:13 pm
I've turned on DEBUG logging to troubleshoot some intermittent issues that I need to 'watch' over a longer period of time.
the current log output's way too huge, getting filled with Library-related info, so reading
   http://wiki.serviio.org/doku.php?id=detail_logging
   http://wiki.serviio.org/doku.php?id=debug_filter
I added to
   config/log4j.xml
the following config
   <category name="org.serviio">
      <priority value="DEBUG"/>
   </category>
   <category name="org.serviio.library.local">
      <priority value="INFO"/>
   </category>
   <category name="org.serviio.library.online">
   </category>
then, deleted existing LOGS and restarted Serviio.
Better, but my logs are still getting filled with irrelevant Library-related info, e.g.,
   2013-08-24 15:56:46,086 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /mnt/Video/TV/tvshow/Season2/tvshow - 2x10 - ep name.mkv
   2013-08-24 15:56:46,086 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /mnt/Video/TV/tvshow/Season2/tvshow - 2x10 - ep name.mkv, ignore case: false
   2013-08-24 15:56:46,086 DEBUG [MediaItemDAOImpl] Media item /mnt/Video/TV/tvshow/Season2/tvshow - 2x10 - ep name.mkv already exists in DB
   2013-08-24 15:56:46,083 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 222) and extractor XBMC
   2013-08-24 15:56:46,087 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 222) and extractor COVER_IMAGE_IN_FOLDER
   2013-08-24 15:56:46,089 DEBUG [MediaItemDAOImpl] Getting file of media item 223
What additional filter can I add to quiet those ^^^ down?
Post Mon Aug 26, 2013 9:01 am
Re: Additional library-related log filters needed
<category name="org.serviio.library.dao">
</category>
or if you don't any debug log from the library
<category name="org.serviio.library">
</category>
Post Mon Aug 26, 2013 11:20 am
Hi zip,
Does this mean there are now three categories to control detailed reporting for the library:
to control reporting for individual components of the library, as well as the overall <category name="org.serviio.library"> if you want just to control it as a single overall entity? While the first two are self explanatory, what does the 3rd one (the .dao) control? Just trying to work out how I add this to my tool viewtopic.php?f=17&t=12136 in a meaningful way (ie. how to explain it to users). It may be easier in my tool to simply act on the entire library - its only meant to be a helper, not necessarily for advanced users/situations, but still this level of detail will be handy to update the wiki (I'll do that if you like).
Post Mon Aug 26, 2013 11:27 am
It's just the way the code is packaged. So the config for .library will work with that + any sub packages (like .library.online). The .dao is just another pubpackage including code that actually talks to the database.
Post Mon Aug 26, 2013 11:43 am
Cheers - have updated http://wiki.serviio.org/doku.php?id=debug_filter. Let me know if you need any changes to it.
Users browsing this forum: Baidu [Spider] and 12 guests
