Serviio and SSD
beto
Post Sun Sep 01, 2013 4:11 pm
Serviio and SSD
my system partition C: is a SSD. As I don't want to have Serviio
write a lot of index files, meta data etc. on the SSD, I installed
Serviio on D: which is a normal hard disk.
Is it right that all index files, meta data etc. are stored in the
subdirectory "library" (which is now on my D: partition)? Or are
there still files that are being written on C:?
Thank you
beto
Post Sun Sep 01, 2013 4:53 pm
Re: Serviio and SSD
Yes that covers all the the library data.
You may want to change the temp folder used for transcoding to D:\ as well then, its under the Transcoding tab of the console.
Users browsing this forum: No registered users and 57 guests
