ogg files, base64 error
tombert
Post Wed Aug 28, 2013 6:53 pm
Hi there, I got a new error:
2013-08-28 20:50:31,685 WARN [LibraryAdditionsCheckerThread] Cannot add file 10 - Warren Hill - It's Always Been You.ogg because of an unexpected error. Message: Length of Ba
se64 encoded input string is not a multiple of 4.
java.lang.IllegalArgumentException: Length of Base64 encoded input string is not a multiple of 4.
at org.jaudiotagger.tag.vorbiscomment.util.Base64Coder.decode(Base64Coder.java:118)
at org.serviio.library.local.metadata.extractor.embedded.OGGExtractionStrategy.getImageDescriptorFromMetadataField(OGGExtractionStrategy.java:87)
at org.serviio.library.local.metadata.extractor.embedded.OGGExtractionStrategy.extractMetadata(OGGExtractionStrategy.java:56)
at org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveAudioMetadata(EmbeddedMetadataExtractor.java:176)
at org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveMetadata(EmbeddedMetadataExtractor.java:115)
at org.serviio.library.local.metadata.extractor.MetadataExtractor.extract(MetadataExtractor.java:46)
at org.serviio.library.local.LibraryManager.extractMetadata(LibraryManager.java:224)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewMediaFile(LibraryAdditionsCheckerThread.java:178)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:145)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:134)
thx for support
tombert
Post Wed Aug 28, 2013 6:58 pm
Re: ogg files, base64 error
found another error:
2013-08-28 20:57:16,463 WARN [LibraryAdditionsCheckerThread] Cannot add file 05 - Zucchero - Rispetto.ogg because of an unexpected error. Message: Illegal character in Base64 encoded data.
java.lang.IllegalArgumentException: Illegal character in Base64 encoded data.
Post Wed Sep 04, 2013 9:25 pm
can you mail me the file? looks like a problem of the library I'm using.
tombert
Post Thu Sep 05, 2013 12:50 pm
you got it at email.cz.
It is 8 MB in size - hope it works.
thx
