Online rss youtube not showing and other problems...1.3.1
abubin
Post Sun Sep 29, 2013 6:16 am
I have been using 1.2.1 on linux and did not want to upgrade when everything is working fine. However around a couple months back i start having problems playing files from youtube. I will get cannot read file error on certain youtube streams.
So i decided to upgrade yesterday. I upgrade by copying files in 1.3.1 into 1.2.1 folder thus preserving library folder. After starting serviio again, i can see all my setting intact. However i am getting problem in my online feeds. I only uses youtube plugin. Some of the feed like weekly to viewed videos i can see only like 4 feeds. Some others have them totally empty. I did a few foece refresh to no avail.
Tgen i decide to clear all my settings. I used exported my online feeds and then removed library folder. Then restarted serviio service to let the library rebuild. Still same problem. Empty feeds and so on. I can confirm the feeds are working cause i open them with pc and they are showing.
Any idea how to fix this?
2013-09-29 15:25:26,071 WARN [MediaServer] DCRAW not found. Support for raw image files will be missing.
Is the dcdraw problem something of concern?
Here is more warnings:
2013-09-29 15:27:03,569 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://r4---sn-uh-30ae.c.youtube.com/vi ... 20AA538D7E. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:454)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:97)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:135)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:297)
abubin
Post Mon Sep 30, 2013 4:24 am
Re: Online rss youtube not showing and other problems...1.3.
no one can help? still having this problem. Dunno what to do now since this is new installation.
Post Mon Sep 30, 2013 5:18 am
Not sure I can help directly - but can say that since 1.3.1 I also get that same warning re: Youtube however it doesn't seem to affect YouTube playback (its only a warning).
Not a lot of help I'm afraid... more for info.
Post Mon Sep 30, 2013 1:16 pm
No Info = No help
Settings, Links and Log = Info
abubin
Post Fri Oct 04, 2013 1:00 pm
I manage to solve the problem. This is due to the ffmpeg package that I installed from ubuntu 12.04. I had to compile my own ffmpeg and now it works. Strange that 1.2.1 was working fine with this ffmpeg for sometime.
So for those running ubuntu 12.04, I suggest you compile your own ffmpeg as per instructions in wiki.
Here are more information for those using ubuntu 12.04:
- i did not remove any existing packages that I had installed previously especially ffmpeg. Cause when I run "apt-get remove ffmpeg", there will be lots of packages marked for removal which includes mysql-server, php, and bunch of other important packages that I need for other usage in the server. So I just compile ffmpeg and it replaced my old ffmpeg file.
