Incorrect Movie Length reported by Serviio
chpyeung
Post Thu Oct 03, 2013 1:51 pm
As my Sony Blu-ray player and Panasonic TV do not like external subtitle files, I have to embed the subtitles into the MKV by using mkvmerge.
Recently when I create MKVs with multiple subtitles and play on my Panasonic TV via Serviio, I found out that the length of the movie shown on the TV are incorrect and a lot longer. Though it still can play fine on TV, problem comes when I want to FF / REW. At first I thought it may be the problem of TV, but today I discover if I use another PC (instead of TV) to browse the movie via Serviio, the wrong reporting of movie length also happens. That will mean the bug is at Serviio, not the TV / PC. There is no problem if I have only one subtitle embedded.
Post Thu Oct 03, 2013 6:24 pm
Re: Incorrect Movie Length reported by Serviio
post ffmpeg -i for the affected file(s), Serviio reads the duration from the output of the command
chpyeung
Post Fri Oct 04, 2013 1:33 pm
zip wrote:post ffmpeg -i for the affected file(s), Serviio reads the duration from the output of the command
Below is the output from file with normal movie length (without any subtitles)
J:\BT\World.War.Z.3D.2013.1080p.BluRay.Half-OU.DTS.x264-PublicHD>ffmpeg.exe -i "
World.War.Z.3D.2013.1080p.BluRay.Half-OU.DTS.x264-PublicHD.mkv" a.mkv
Input #0, matroska,webm, from 'World.War.Z.3D.2013.1080p.BluRay.Half-OU.DTS.x264
-PublicHD.mkv':
    creation_time   : 2013-09-07 05:28:52
  Duration: 01:56:04.75, start: 0.000000, bitrate: 15193 kb/s
    Chapter #0.0: start 0.000000, end 305.180000
      title           : 00:00:00.000
    Chapter #0.1: start 305.180000, end 784.659000
      title           : 00:05:05.180
    Chapter #0.2: start 784.659000, end 1231.188000
      title           : 00:13:04.659
    Chapter #0.3: start 1231.188000, end 1622.579000
      title           : 00:20:31.188
    Chapter #0.4: start 1622.579000, end 1958.039000
      title           : 00:27:02.579
    Chapter #0.5: start 1958.039000, end 2375.331000
      title           : 00:32:38.039
    Chapter #0.6: start 2375.331000, end 2946.152000
      title           : 00:39:35.331
    Chapter #0.7: start 2946.152000, end 3322.027000
      title           : 00:49:06.152
    Chapter #0.8: start 3322.027000, end 3701.239000
      title           : 00:55:22.027
    Chapter #0.9: start 3701.239000, end 4158.654000
      title           : 01:01:41.239
    Chapter #0.10: start 4158.654000, end 4623.035000
      title           : 01:09:18.654
    Chapter #0.11: start 4623.035000, end 4929.842000
      title           : 01:17:03.035
    Chapter #0.12: start 4929.842000, end 5271.558000
      title           : 01:22:09.842
    Chapter #0.13: start 5271.558000, end 5801.587000
      title           : 01:27:51.558
    Chapter #0.14: start 5801.587000, end 6314.099000
      title           : 01:36:41.587
    Chapter #0.15: start 6314.099000, end 6526.645000
      title           : 01:45:14.099
    Chapter #0.16: start 6526.645000, end 6964.750000
      title           : 01:48:46.645
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080, SAR 1:1 DAR 16:9,
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      stereo_mode     : top_bottom
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (de
fault)
File 'a.mkv' already exists. Overwrite ? [y/N] n
Not overwriting - exiting
Now is the output from the file with incorrect movie length that I have embedded 2 subtitles
World.War.Z.3D.2013.1080p.BluRay.Half-OU.DTS.x264-PublicHD.eng.mkv" a.mkv
-PublicHD.eng.mkv':
    creation_time   : 2013-10-02 15:10:59
  Duration: 01:56:04.75, start: 0.000000, bitrate: 15198 kb/s
fault)
    Stream #0:2(eng): Subtitle: dvd_subtitle (default)
    Stream #0:3(eng): Subtitle: subrip
It does not seem to have any info about movie length!
Please see below the screen capture showing the incorrect length and also incorrect file size when browsing the files via Serviio!
Post Fri Oct 04, 2013 4:25 pm
If Serviio transcodes the file (eg because the embedded subtitle has been found and burn-in is required), it will send a very large file size, so maybe it's this case and the TV retrieves the duration from the file size.
FFMpeg finds the correct duration, so Serviio should too (and it does for the other 3 files).
Try to disable embedded subtitles and/or burned in subs setting.
chpyeung
Post Sat Oct 05, 2013 4:12 am
Thanks for your reply. I disable transcoding and subtitles and restart the server and serviio service. After that, the file size and duration is back to normal.
Furthermore, I found that this problem exists only on 3D movies (H-SBS or H-OU). (Maybe it is not right, but the errors in duration are on 2 3D movies I recently merged. And there is no problem for 2D movies with multiple subtitles.)
