Serviio Service in Windows 7 keeps stopping.
DevXen
Post Sat Sep 28, 2013 8:07 am
With the last version of Serviio my server would service would stop within hours, or sometimes a couple days.. so i'd open up services.msc and restart the service, though annoying, problem is solved.. since i updated to the newest serviio it is either stopping immediately or within a few seconds. any help would be appreciated. I just updated Java, that didn't help. Here's my log.
2013-09-28 02:04:57,943 INFO  [MediaServer] ------------------------------------------------------------------------
2013-09-28 02:04:57,943 INFO  [MediaServer] Serviio DLNA media streaming server v 1.3.1 (rev. f1fc8bc55657)
2013-09-28 02:04:57,943 INFO  [MediaServer] Petr Nejedly 2009-2013
2013-09-28 02:04:57,959 INFO  [MediaServer] http://www.serviio.org
2013-09-28 02:04:57,959 INFO  [MediaServer] Java 1.7.0_40-Oracle Corporation
2013-09-28 02:04:57,959 INFO  [MediaServer] OS Windows 7 x86 6.1
2013-09-28 02:04:57,959 INFO  [MediaServer] File encoding: windows-1252
2013-09-28 02:04:57,959 INFO  [MediaServer] Headless mode enabled: true
2013-09-28 02:04:57,959 INFO  [MediaServer] User: DEVXEN-PC$
2013-09-28 02:04:57,959 INFO  [MediaServer] User home dir: C:\
2013-09-28 02:04:57,959 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-09-28 02:04:57,959 INFO  [MediaServer] ------------------------------------------------------------------------
2013-09-28 02:04:58,161 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-09-28 02:04:58,161 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-09-28 02:04:58,239 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-09-28 02:04:58,239 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-09-28 02:04:58,271 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-09-28 02:04:59,160 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@13e6f83, see the next exception for details.
   at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
   at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
   at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
   at org.apache.derby.jdbc.Driver20.connect(Unknown Source)
   at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
   at java.sql.DriverManager.getConnection(Unknown Source)
   at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:66)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:59)
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
   at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:59)
   at org.serviio.MediaServer.main(MediaServer.java:115)
   at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
   at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@13e6f83, see the next exception for details.
   ... 26 more
Caused by: java.sql.SQLException: Java exception: 'Unknown constant tag 115 in class file org/apache/derby/iapi/store/raw/data/DataFactory: java.lang.ClassFormatError'.
   at org.apache.derby.impl.jdbc.Util.javaException(Unknown Source)
   ... 23 more
Caused by: java.lang.ClassFormatError: Unknown constant tag 115 in class file org/apache/derby/iapi/store/raw/data/DataFactory
   at java.lang.ClassLoader.defineClass1(Native Method)
   at java.lang.ClassLoader.defineClass(Unknown Source)
   at java.security.SecureClassLoader.defineClass(Unknown Source)
   at java.net.URLClassLoader.defineClass(Unknown Source)
   at java.net.URLClassLoader.access$100(Unknown Source)
   at java.net.URLClassLoader$1.run(Unknown Source)
   at java.net.URLClassLoader.findClass(Unknown Source)
   at java.lang.ClassLoader.loadClass(Unknown Source)
   at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
   at java.lang.Class.forName0(Native Method)
   at java.lang.Class.forName(Unknown Source)
   at org.apache.derby.impl.services.monitor.ProtocolKey.create(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)
   at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)
   at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
   at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
   at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
   at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
   ... 23 more
2013-09-28 02:05:01,188 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
2013-09-28 02:05:12,326 INFO  [MediaServer] ------------------------------------------------------------------------
2013-09-28 02:05:12,326 INFO  [MediaServer] Serviio DLNA media streaming server v 1.3.1 (rev. f1fc8bc55657)
2013-09-28 02:05:12,326 INFO  [MediaServer] Petr Nejedly 2009-2013
2013-09-28 02:05:12,326 INFO  [MediaServer] http://www.serviio.org
2013-09-28 02:05:12,326 INFO  [MediaServer] Java 1.7.0_40-Oracle Corporation
2013-09-28 02:05:12,326 INFO  [MediaServer] OS Windows 7 x86 6.1
2013-09-28 02:05:12,326 INFO  [MediaServer] File encoding: windows-1252
2013-09-28 02:05:12,326 INFO  [MediaServer] Headless mode enabled: true
2013-09-28 02:05:12,326 INFO  [MediaServer] User: DEVXEN-PC$
2013-09-28 02:05:12,326 INFO  [MediaServer] User home dir: C:\
2013-09-28 02:05:12,326 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-09-28 02:05:12,623 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-09-28 02:05:12,623 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-09-28 02:05:12,701 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-09-28 02:05:12,701 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-09-28 02:05:12,747 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-09-28 02:05:13,699 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
   ... 26 more
   ... 23 more
   ... 23 more
2013-09-28 02:05:14,495 INFO  [ServiioConsole] Initializing Serviio Console
2013-09-28 02:05:14,526 INFO  [ServiioConsole] Starting Serviio Console
2013-09-28 02:05:14,697 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-09-28 02:05:15,774 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
2013-09-28 02:05:18,989 INFO  [MediaServer] ------------------------------------------------------------------------
2013-09-28 02:05:18,989 INFO  [MediaServer] Serviio DLNA media streaming server v 1.3.1 (rev. f1fc8bc55657)
2013-09-28 02:05:18,989 INFO  [MediaServer] Petr Nejedly 2009-2013
2013-09-28 02:05:18,989 INFO  [MediaServer] http://www.serviio.org
2013-09-28 02:05:18,989 INFO  [MediaServer] Java 1.7.0_40-Oracle Corporation
2013-09-28 02:05:18,989 INFO  [MediaServer] OS Windows 7 x86 6.1
2013-09-28 02:05:18,989 INFO  [MediaServer] File encoding: windows-1252
2013-09-28 02:05:18,989 INFO  [MediaServer] Headless mode enabled: true
2013-09-28 02:05:18,989 INFO  [MediaServer] User: DEVXEN-PC$
2013-09-28 02:05:18,989 INFO  [MediaServer] User home dir: C:\
2013-09-28 02:05:18,989 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-09-28 02:05:19,223 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-09-28 02:05:19,223 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-09-28 02:05:19,301 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-09-28 02:05:19,301 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-09-28 02:05:19,333 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-09-28 02:05:20,456 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
   ... 26 more
   ... 23 more
   ... 23 more
2013-09-28 02:05:22,484 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
2013-09-28 02:05:26,853 INFO  [MediaServer] ------------------------------------------------------------------------
2013-09-28 02:05:26,853 INFO  [MediaServer] Serviio DLNA media streaming server v 1.3.1 (rev. f1fc8bc55657)
2013-09-28 02:05:26,853 INFO  [MediaServer] Petr Nejedly 2009-2013
2013-09-28 02:05:26,853 INFO  [MediaServer] http://www.serviio.org
2013-09-28 02:05:26,853 INFO  [MediaServer] Java 1.7.0_40-Oracle Corporation
2013-09-28 02:05:26,853 INFO  [MediaServer] OS Windows 7 x86 6.1
2013-09-28 02:05:26,853 INFO  [MediaServer] File encoding: windows-1252
2013-09-28 02:05:26,853 INFO  [MediaServer] Headless mode enabled: true
2013-09-28 02:05:26,853 INFO  [MediaServer] User: DEVXEN-PC$
2013-09-28 02:05:26,853 INFO  [MediaServer] User home dir: C:\
2013-09-28 02:05:26,853 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-09-28 02:05:27,087 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-09-28 02:05:27,103 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-09-28 02:05:27,181 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-09-28 02:05:27,181 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-09-28 02:05:27,212 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-09-28 02:05:28,507 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
   ... 26 more
   ... 23 more
   ... 23 more
2013-09-28 02:05:30,613 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
2013-09-28 02:05:40,488 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2013-09-28 02:05:50,643 WARN  [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2013-09-28 02:05:50,643 INFO  [Messages] Loaded console message bundle for locale: en
it does say it could'nt connect cause the server won't run, but as i said, it stops running after just a couple seconds, while getting this log, i clicked on start maybe 4 times, to get it to try to start long enough to help the log. anyhow. any advice?
-Dev
Post Tue Oct 01, 2013 8:51 pm
Re: Serviio Service in Windows 7 keeps stopping.
It looks like some corrupted installation files. Did you try reinstalling Serviio?
DevXen
Post Tue Oct 29, 2013 10:53 pm
zip wrote:It looks like some corrupted installation files. Did you try reinstalling Serviio?
Sorry I didn't get your email, saying you replied. or I would have replied sooner.
Yes i reinstalled Serviio, and then uninstalled it and reinstalled it. a couple times.
same thing.
Post Wed Oct 30, 2013 9:36 pm
You could try different java version, but it does look like some of the files in lib folder are corrupted, for whatever reason.
Users browsing this forum: Baidu [Spider] and 45 guests
