Serviio Windows Service Randomly stops
DevXen
Post Tue Oct 29, 2013 10:47 pm
So the Serviio Service in windows 7. on THIS PC. keeps stopping. from in a few hours, to a few days. I just now tried to open the console with an error 500 and it said to check the log.. this was in the log, so I assume, it was part of the issue.. Serviio on my other PC works, and runs just fine.. i just updated Java on this PC.. and just updated all the windows updates, but this problem has been going on for several weeks.. anyone have any idea on how i can fix it?
2013-10-29 16:41:26,925 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Java exception: ': java.lang.NullPointerException'.
   at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
   at org.apache.derby.impl.jdbc.Util.javaException(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
   at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
   at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
   at org.apache.derby.jdbc.Driver20.connect(Unknown Source)
   at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
   at java.sql.DriverManager.getConnection(Unknown Source)
   at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:66)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:59)
   at org.serviio.renderer.dao.RendererDAOImpl.findByIPAddress(RendererDAOImpl.java:144)
   at org.serviio.renderer.RendererManager.getStoredRendererByIPAddress(RendererManager.java:226)
   at org.serviio.renderer.RendererManager.rendererHasAccess(RendererManager.java:235)
   at org.serviio.upnp.webserver.AbstractRequestHandler.callerHasAccess(AbstractRequestHandler.java:148)
   at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
Caused by: java.sql.SQLException: Java exception: ': java.lang.NullPointerException'.
   ... 28 more
Caused by: java.lang.NullPointerException
   at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openContainer(Unknown Source)
   at org.apache.derby.impl.store.raw.xact.Xact.openContainer(Unknown Source)
   at org.apache.derby.impl.store.access.conglomerate.OpenConglomerate.init(Unknown Source)
   at org.apache.derby.impl.store.access.heap.Heap.open(Unknown Source)
   at org.apache.derby.impl.store.access.RAMTransaction.openConglomerate(Unknown Source)
   at org.apache.derby.impl.sql.catalog.DataDictionaryImpl.getDescriptorViaIndexMinion(Unknown Source)
   at org.apache.derby.impl.sql.catalog.DataDictionaryImpl.getDescriptorViaIndex(Unknown Source)
   at org.apache.derby.impl.sql.catalog.DataDictionaryImpl.locateSchemaRow(Unknown Source)
   at org.apache.derby.impl.sql.catalog.DataDictionaryImpl.getSchemaDescriptor(Unknown Source)
   at org.apache.derby.impl.sql.conn.GenericLanguageConnectionContext.initDefaultSchemaDescriptor(Unknown Source)
   at org.apache.derby.impl.sql.conn.GenericLanguageConnectionContext.initialize(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase.setupConnection(Unknown Source)
   at org.apache.derby.impl.jdbc.TransactionResourceImpl.startTransaction(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.checkUserIsNotARole(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.checkUserCredentials(Unknown Source)
   ... 22 more
Post Wed Oct 30, 2013 9:22 pm
Re: Serviio Windows Service Randomly stops
Weird, looks like the database engine has problems accessing the database files. Check the drive, access rights, etc where Serviio is installed.
DevXen
Post Thu Oct 31, 2013 5:47 am
zip wrote:Weird, looks like the database engine has problems accessing the database files. Check the drive, access rights, etc where Serviio is installed.
Yeah it's the C Drive, and has full access to the drive..
odd with this error, if i restarted the console it would open. but have no folders listed.
but if I closed it. stopped the windows Service for Serviio. then restarted it. opened up the console. they were there, and it all worked.
