Serviio console display problems
cisop
Post Fri Nov 22, 2013 7:37 pm
I have Serviio 1.3.1 running on Windows 8.1. It is serving media throughout my house to several tv's and laptops. It is working fine.
Serviio runs 24 hours a day. After 3 or 4 days running the library screen display screws up. When you load the console you can change to any tab ,except the library tab ,and everything works fine. But if you change to the library screen nothing happens. Whatever was on the screen before selecting the library screen stays on the screen. However if you click on the screen bits and pieces of the library screen start to appear. Every time you click the screen the area under the mouse cursor becomes the library screen.
It is as if the initial screen did not get cleared before the library screen was displayed. As soon as you start clicking on it the underlying library screen starts to appear. I did not test further to see if the library screen was functional but I suspect it is. It is only the display that is messed up. I should have took a screen print but I did not.
The problem is easily fixed by exiting the console and restarting it.
The operation of the Serviio server is not affected in any way.
It all sounds a little confusing. I hope this makes sense.
If you would like me to try anything let me know. I would be glad to help.
cisop
Post Mon Nov 25, 2013 7:06 pm
Re: Serviio console display problems
Might be cause by Java, try to install a newer version, if it's causing you troubles.
cisop
Post Tue Nov 26, 2013 2:47 am
I have Java version 7.0.50 installed, which I believe is current.
cisop
Post Wed Nov 27, 2013 5:39 pm
Might be current. doesn't mean it's not buggy ;-)
Users browsing this forum: Baidu [Spider] and 59 guests
