BUG: Serviio not able to scan library with "é" in folder's
thenamelessthing
Post Thu Dec 12, 2013 1:15 pm
Hi, i'm under serviio 1.3.1. I want to notice you about a bug I have found.
In my library I have added /data/musiques for my music library. Sub-folder name containing é are not scan by serviio. Maybe because it doesn't support french special character?
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Post Thu Dec 12, 2013 5:28 pm
Re: BUG: Serviio not able to scan library with "é" in folder
That should work. Can you remove the file, enable detaiuled log, add the file back and then post the log?
Users browsing this forum: Google [Bot] and 64 guests
