WDTV just lost audio for everything?
sleky
Post Wed Dec 11, 2013 10:35 pm
I think it is an issue with the profile?
2013-12-11 16:11:14,136 DEBUG [cache] Could not find template in cache, creating new one; id=[org/serviio/upnp/protocol/templates/deviceDescription.ftl[en_US,UTF-8,parsed] ]
2013-12-11 16:11:14,137 DEBUG [cache] Compiling FreeMarker template org/serviio/upnp/protocol/templates/deviceDescription.ftl[en_US,UTF-8,parsed]  from jar:file:/usr/share/serviio/lib/serviio.jar!/org/serviio/upnp/protocol/templates/deviceDescription.ftl
2013-12-11 16:11:14,250 DEBUG [cache] Could not find template in cache, creating new one; id=[org/serviio/upnp/protocol/templates/serviceDescription-MediaReceiverRegistrar.ftl[en_US,UTF-8,parsed] ]
2013-12-11 16:11:14,250 DEBUG [cache] Compiling FreeMarker template org/serviio/upnp/protocol/templates/serviceDescription-MediaReceiverRegistrar.ftl[en_US,UTF-8,parsed]  from jar:file:/usr/share/serviio/lib/serviio.jar!/org/serviio/upnp/protocol/templates/serviceDescription-MediaReceiverRegistrar.ftl
2013-12-11 16:11:14,263 DEBUG [cache] Could not find template in cache, creating new one; id=[org/serviio/upnp/protocol/templates/serviceDescription-ContentDirectory.ftl[en_US,UTF-8,parsed] ]
2013-12-11 16:11:14,264 DEBUG [cache] Compiling FreeMarker template org/serviio/upnp/protocol/templates/serviceDescription-ContentDirectory.ftl[en_US,UTF-8,parsed]  from jar:file:/usr/share/serviio/lib/serviio.jar!/org/serviio/upnp/protocol/templates/serviceDescription-ContentDirectory.ftl
2013-12-11 16:11:14,290 DEBUG [cache] Could not find template in cache, creating new one; id=[org/serviio/upnp/protocol/templates/serviceDescription-ConnectionManager.ftl[en_US,UTF-8,parsed] ]
2013-12-11 16:11:14,290 DEBUG [cache] Compiling FreeMarker template org/serviio/upnp/protocol/templates/serviceDescription-ConnectionManager.ftl[en_US,UTF-8,parsed]  from jar:file:/usr/share/serviio/lib/serviio.jar!/org/serviio/upnp/protocol/templates/serviceDescription-ConnectionManager.ftl
2013-12-11 16:11:15,258 DEBUG [cache] org/serviio/upnp/protocol/templates/deviceDescription.ftl[en_US,UTF-8,parsed] cached copy not yet stale; using cached.
2013-12-11 16:12:39,083 DEBUG [cache] org/serviio/upnp/protocol/templates/deviceDescription.ftl[en_US,UTF-8,parsed] using cached since jar:file:/usr/share/serviio/lib/serviio.jar!/org/serviio/upnp/protocol/templates/deviceDescription.ftl didn't change.
2013-12-11 16:12:44,565 DEBUG [CompositeCache] get: key = V_M:BrowseDirectChildren:ALL:dc:title,res,res@protection,res@duration,res@bitrate,upnp:genre,upnp:actor,res@microsoft:codec:0:1000:+upnp:class,+dc:title:3:1, localOnly = false
2013-12-11 16:12:44,565 DEBUG [LRUMemoryCache] getting item from cache local_default for key V_M:BrowseDirectChildren:ALL:dc:title,res,res@protection,res@duration,res@bitrate,upnp:genre,upnp:actor,res@microsoft:codec:0:1000:+upnp:class,+dc:title:3:1
2013-12-11 16:12:44,566 DEBUG [LRUMemoryCache] local_default: LRUMemoryCache miss for V_M:BrowseDirectChildren:ALL:dc:title,res,res@protection,res@duration,res@bitrate,upnp:genre,upnp:actor,res@microsoft:codec:0:1000:+upnp:class,+dc:title:3:1
2013-12-11 16:12:44,566 DEBUG [LRUMemoryCache] verifycache[local_default]: mapContains 0 elements, linked list contains 0 elements
I've tried a few different videos. I get picture but no sound. When I check the audio options on the WD TV it says Audio Channel: No audio channel
sleky
Post Thu Dec 12, 2013 3:02 am
Re: WDTV just lost audio for everything?
Will get some ffmpeg information for relevant videos. Seems its just the Ancient Aliens are the issue. I got everything working again except for these videos.
log.txt
(22.74 KiB) Downloaded 330 times
sleky
Post Thu Dec 12, 2013 2:20 pm
ffmpeg info...
root@nix-01:/mnt/usb3/TV/Ancient Aliens# ffmpeg -i Ancient\ Aliens\ S01E01.mp4
ffmpeg version N-57549-g269b3c8 Copyright (c) 2000-2013 the FFmpeg developers
  built on Oct 28 2013 12:19:55 with gcc 4.7 (Debian 4.7.2-5)
  configuration: --prefix=/root/ffmpeg_build --extra-cflags=-I/root/ffmpeg_build/include --extra-ldflags=-L/root/ffmpeg_build/lib --bindir=/usr/bin --extra-libs=-ldl --enable-gpl --enable-libass --enable-libfdk-aac --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree
  libavutil      52. 48.100 / 52. 48.100
  libavcodec     55. 39.100 / 55. 39.100
  libavformat    55. 19.104 / 55. 19.104
  libavdevice    55.  5.100 / 55.  5.100
  libavfilter     3. 90.100 /  3. 90.100
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 17.104 /  0. 17.104
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Ancient Aliens S01E01.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isom
    creation_time   : 2013-10-26 23:23:13
    title           : Ancient Aliens S01E01 (The Evidence)
  Duration: 01:27:53.87, start: 0.000000, bitrate: 1788 kb/s
    Stream #0:0(eng): Video: h264 (High 10) (avc1 / 0x31637661), yuv420p10le, 1280x720, 1655 kb/s, 23.98 fps, 23.98 tbr, 15869500.00 tbn, 4534142.86 tbc (default)
      creation_time   : 2013-10-23 09:37:06
      handler_name    : GPAC ISO Video Handler
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default)
      creation_time   : 2013-10-26 23:24:44
      handler_name    : GPAC ISO Audio Handler
    Stream #0:2(eng): Data: none (mp4s / 0x7334706D), 0 kb/s (default)
      creation_time   : 2013-10-26 23:25:40
      handler_name    : GPAC MPEG-4 OD Handler
    Stream #0:3(eng): Data: none (mp4s / 0x7334706D), 0 kb/s (default)
      creation_time   : 2013-10-26 23:25:41
      handler_name    : GPAC MPEG-4 Scene Description Handler
    Stream #0:4(eng): Subtitle: mov_text (tx3g / 0x67337874), 1280x720, 0 kb/s (default)
root@nix-01:/mnt/usb3/TV/Ancient Aliens# ffmpeg -i Ancient\ Aliens\ S01E02.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Ancient Aliens S01E02.mp4':
    major_brand     : isom
    minor_version   : 1
    creation_time   : 2013-10-30 06:20:20
    title           : Ancient Aliens S01E02 (The Visitors)
  Duration: 01:28:02.29, start: 0.000000, bitrate: 1787 kb/s
      creation_time   : 2013-10-23 16:00:50
    Stream #0:1(eng): Data: none (mp4s / 0x7334706D), 0 kb/s (default)
      creation_time   : 2013-10-30 06:20:47
    Stream #0:3(eng): Subtitle: mov_text (tx3g / 0x67337874), 1280x720, 0 kb/s (default)
      creation_time   : 2013-10-26 23:32:32
    Stream #0:4(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default)
      creation_time   : 2013-10-30 06:20:53
    Stream #0:5(eng): Data: none (mp4s / 0x7334706D), 0 kb/s (default)
      creation_time   : 2013-10-30 06:20:54
    Stream #0:6(eng): Data: none (mp4s / 0x7334706D), 0 kb/s (default)
      creation_time   : 2013-10-30 06:20:55
root@nix-01:/mnt/usb3/TV/Ancient Aliens# ffmpeg -i Ancient\ Aliens\ S01E03.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Ancient Aliens S01E03.mp4':
    major_brand     : isom
    minor_version   : 1
    creation_time   : 2013-10-26 23:35:10
    title           : Ancient Aliens S01E03 (The Mission)
  Duration: 01:27:58.31, start: 0.000000, bitrate: 1788 kb/s
      creation_time   : 2013-10-23 20:48:00
      creation_time   : 2013-10-26 23:36:24
      creation_time   : 2013-10-26 23:38:40
      creation_time   : 2013-10-26 23:38:45
      creation_time   : 2013-10-26 23:38:47
root@nix-01:/mnt/usb3/TV/Ancient Aliens# ffmpeg -i Ancient\ Aliens\ S06E01.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Ancient Aliens S06E01.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2013-10-01 05:45:36
  Duration: 00:43:59.59, start: 0.000000, bitrate: 869 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 720x400, 744 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc (default)
      handler_name    : Aliens.S06E01.The.Power.of.Three.720p.HDTV.264#trackID=1:fps=23.976@GPAC0.5.1-DEV-rev4283
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 121 kb/s (default)
      creation_time   : 2013-10-01 05:21:22
      handler_name    : Sound Media Handler
Post Thu Dec 12, 2013 5:18 pm
were these working before? if yes, then it's not a profile issue, more like something caused by the WDTV (update?)
sleky
Post Thu Dec 12, 2013 8:17 pm
I don't think they ever worked. Just these videos, from one source. A one off... I can play them fine on mediabrowser, and then I am just streaming them to my chromecast. I'm getting my content in the end. Just was odd that I lost all audio and those video's at the same time. Not to worried about delving into this too deep as I have other items to work on. Just didn't know if anything stood out or there might be a bigger issue. :geek:
Thanks again Zip
Users browsing this forum: No registered users and 54 guests
