update to server 1.4 won't start
epster
Post Fri Dec 27, 2013 8:24 pm
I'm running Win7. After the update to 1.4 the service won't start. Doesn't show up in the services console either. Downloaded again & re-installed but no help. So I finally went to command prompt
Got the error code 1060 which means "The specified service does not exist as an installed service." Not sure where to go from here.
epster
Post Sat Dec 28, 2013 2:56 am
Re: update to server 1.4 won't start
solved the problem by doing a uninstall and reinstall
