PS3 refuse to play some .mkv, Serviio says it's ffmpeg.
yoGhurt
Post Mon Dec 30, 2013 8:30 pm
Hi
My problem is that some .mkv files cannot be played (transcoded) on PS3. Thing is, that after I start specific file, I've got 01F4 error from PS3. Of course, it's only when I've got checked all 3 options in "subtitles" card in Serviio options.
I looked into debbug log and got this:
2013-12-30 19:59:09,483 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error. Detailed output follows.
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
Stream #0:1(eng): Audio: ac3, 48000 Hz, stereo, fltp, 384 kb/s (default)
[Parsed_subtitles_0 @ 0219EB80] Unable to open E:/Breaking Bad - Season 1 720p HDTV x264/Breaking.Bad.S01E01.720p.HDTV.x264-BiA.srt
[AVFilterGraph @ 01A8D020] Error initializing filter 'subtitles' with args 'filename=E\:/Breaking Bad - Season 1 720p HDTV x264/Breaking.Bad.S01E01.720p.HDTV.x264-BiA.srt:original_size=1280x720:charenc=UTF-8'
Error opening filters!
2013-12-30 19:59:09,483 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
Like I saw suggestions, I run same command manually from command line and have got something new.
Fontconfig error: Cannot load default config file
[Parsed_subtitles_0 @ 0197E220] No usable fontconfig configuration file found, u
sing fallback.
[Parsed_subtitles_0 @ 0197E220] Unable to open E:/Breaking Bad - Season 1 720p H
[AVFilterGraph @ 01973A80] Error initializing filter 'subtitles' with args 'file
I updated ffmpeg but it didn't help.
I tried some custom font.conf files but it was only worse. Anyone have idea what should be next step or any good font.conf file?
Here is whole debbug log http://sdrv.ms/1cic1De. I know that I should add some filters for file and it would be smaller, but it forgot about that, my bad.
Post Tue Dec 31, 2013 1:12 pm
Re: PS3 refuse to play some .mkv, Serviio says it's ffmpeg.
What is your OS, linux ?
For linux system, you have to use a ffmpeg package with some filters options : http://www.serviio.org/download
This release includes FFmpeg (post) 1.2.1 compiled using this source code, libRTMP 2.4+ compiled using this source code, Lame MP3 Encoder (v. 3.99.5) compiled using this source code. Refer to README.txt for the complete list.
yoGhurt
Post Tue Dec 31, 2013 2:02 pm
Illico wrote:What is your OS, linux ?
My OS is Windows Server 2012 (Essentials).
Post Thu Jan 02, 2014 8:53 am
Could you post your "srt" file? It seems that ffmpeg can not access it.
yoGhurt
Post Thu Jan 02, 2014 1:02 pm
Illico wrote:Could you post your "srt" file? It seems that ffmpeg can not access it.
Here is .srt http://sdrv.ms/1eXKSNX. I checked permissions for files and there shouldn't be problem with that, but in meantime, i'll try to test something. Files are also writeable.
Post Thu Jan 02, 2014 5:15 pm
This is not a srt format
yoGhurt
Post Thu Jan 02, 2014 6:24 pm
I see what you tried to say. That shema inside my file isn't proper for .srt format.
My is "[0000][0001] something", in proper .srt is "00:03:10,500 --> 00:00:13,000 something" etc.
Interesting that my media player on PC hadn't problem with those wrong files.
Anyway, thanks.
