moovie not compatible with my servio and or PS3
common26
Post Sat Jan 04, 2014 3:21 pm
I trying to play a movie and is giving me a imcopatible msg in the PS3, but the log doesnt even register a error or something...
here is the info of the file:
Complete name : E:\Server\Movies\Latino\A Single Shot.2013.DVDrip.XviD.Subtitulado.SBT.avi
Format : AVI
File size : 630 MiB
Duration : 1h 55mn
Overall bit rate : 761 Kbps
Writing application : MEncoder r33883
Writing library : MPlayer
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 55mn
Source duration : 1h 55mn
Bit rate : 627 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Original display aspect ratio : 3:2
Frame rate : 25.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.073
Stream size : 519 MiB (82%)
Writing library : XviD 63
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 55mn
Bit rate mode : Variable
Bit rate : 122 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 101 MiB (16%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (0.65 video frame)
Interleave, preload duration : 477 ms
How to make it work in PS3
Thanks!
Post Sun Jan 05, 2014 7:26 am
Re: moovie not compatible with my servio and or PS3
Moved to Support & help section.
I couldnt see anything that stands out for the file - you could try remuxing it and seeing if that helps. Use the command
ffmpeg -i "E:\Server\Movies\Latino\A Single Shot.2013.DVDrip.XviD.Subtitulado.SBT.avi" -map 0 -c copy "E:\Server\Movies\Latino\test.avi"
common26
Post Tue Jan 07, 2014 2:39 am
It works Flawless fro this file :)
Thanks!!!!!!!!!!!!!!!!!!!
Users browsing this forum: Baidu [Spider] and 32 guests
