Problem streaming to WDTV
heffa
Post Thu Jan 09, 2014 7:05 pm
Hello
Can anyone please help we and explain why I cant see any files in my Serviio server.
I have set up the server according to any number of guides (found on youtube) and I have added alla the online and local resources that I want to stream. The problem is that i can see and log on to the Serviio server but I cant see any files.
First I thought that it was only problems with the WDTV but i tried it on my ipad2 and I had the same problem there, I could find the server but no files inside.
Has anyone els seen this problem before.
Post Thu Jan 09, 2014 11:18 pm
Re: Problem streaming to WDTV
Can you see any media using Serviio's Mediabrowser (from the PC Servio is on open http://192.168.0.2:23424/mediabrowser from your browser).
Looking at local files only - you need to ensure the Serviio service has full access to the drives and folders that your media is located on (are these remote drives, or located on the same PC?). Have a look at http://www.serviio.org/component/conten ... e?id=21#q5.
Also, where are you looking (which category - Folders, Movies, Series, etc...). Check the Folders category first.
