unable to get Online streaming/content
luca
Post Tue Nov 19, 2013 10:33 pm
I have spent the last few days learning alot and after a few false starts, finally managed to get serviio working on my Synology NAS for music, video etc stored on the NAS. This works on my local network and remotely.
Now I have turned my attention to getting online live TV etc. e.g. BBC iplayer, you tube etc. I have added 2 different groovy files to the //serviio/plugins directory, the iplayer.groovy and ITVplayer.groovy.
I then tried a range of different web sources, Rss feeds from the BBC website etc and can get nothing to work. The online folder is showing as empty on all the devices I have tried (ipad, android tablet, tv).
When I put the different feeds into a player like VLC media player, nothing plays - makes me think I am using the wrong addressing? Or is there a crucial set up step I am missing?
Post Wed Nov 20, 2013 6:42 pm
Re: unable to get Online streaming/content
First, are you in UK (for iPlayer)?
What are the URLs you are using? Post ServiioLink here (right click on online source in the console, Copy As SeviioLink)
Post Wed Nov 27, 2013 10:47 pm
Some of these are live streams (?) which for example the iPlayer plugin doesn't support. the ITV Downton abbey should work - can you see at least the video when you browse the Online sources? Or is the folder empty?
luca
Post Thu Nov 28, 2013 8:08 pm
The folder is empty.
Thanks,
ViverraXX
Post Fri Nov 29, 2013 8:16 am
luca wrote:Hi,
Thanks,
Me too. While ServiiO not have do checking every URL, it not show in the list of available channels. I use TorrentTV and checking of availability too heavy.
SolihullRog
Post Tue Feb 04, 2014 12:43 pm
Me too.
Serviio gives a red X when I check all of your URLs. Perhaps they aren't broadcasting now?
But I get the same reaction to every online source that I try to add to Serviio.
I've read every Serviio website that seems relevant.
It seems like a good product, but my free trial is rapidly running out, and I will regretfully lose it if I don't find a solution...
alfista
Post Wed Feb 05, 2014 8:10 am
SolihullRog wrote:It seems like a good product, but my free trial is rapidly running out, and I will regretfully lose it if I don't find a solution...
Possibility to stream online content is not limited to the trial period.
SolihullRog
Post Wed Feb 05, 2014 11:56 am
Thanks, Alfista.
So I can fail to stream for a long time then!
SolihullRog
Post Wed Feb 05, 2014 12:00 pm
IGNORE THIS POST - zip just told me this, which is a major breakthrough to me!
Usually, if you just have a website URL that has some player on it, it won't just work in Serviio. The URL points to some HTML code (page source code) and the embedded player then uses a real video stream URL to access the media. That URL is normally hidden to users and might be hard to find. That's when plugins come to play, as they have the code needed to work out the media URL. There are many plugins available on this forum, but there might not be one for the particular page/server you want to use. There is not fit-them-all solution.
The types are:
- online stream - for URLs that are already video streams (not web pages) - ie, what the embedded player on a web page might use. This is only useful if you know that URL and normally only available for live streams (not VOD content)
- rss feed - used when you have a feed with a list of videos. Sometimes the feed includes actual video URLs, in which case it doesn't need plugin. In other cases it includes list of web page URLs (e.g. YouTube), in which case it needs a plugin.
- web resource - used when there is no structured feed. It always requires a plugin. You enter a web page URL (one that the plugin requires, see the plugin description on this forum), the plugin will try to work out the list of videos on that page and then try to get the video stream URL for each of these videos.
As I said, i'ts not trivial, but you might find serviidb.org useful (or it's integration in ServiiDroid or other 3rd party UI apps).
I recently posted this elsewhere, but it might add to this thread. I hope it does.
've been trying to get Serviio streaming from the internet working, and failed with all except samples from this forum.
In particular the NASA stream works without a plugin (I think).
My detailed log, containing various attempts, show
2014-02-05 11:25:55,866 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www7.aoso.ru/2012/11/2.html has been found.
2014-02-05 11:25:55,866 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www7.aoso.ru/2012/11/1.html has been found.
2014-02-05 11:25:55,875 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.cwtv.com/ has been found.
2014-02-05 11:25:55,878 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.foodnetwork.co.uk/?omnisource=gid_uk has been found.
2014-02-05 11:25:55,878 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.myp2p-eu.net/p/other-sport-myp2p.html has been found.
2014-02-05 11:26:55,881 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www7.aoso.ru/2012/11/2.html has been found.
2014-02-05 11:26:55,881 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www7.aoso.ru/2012/11/1.html has been found.
2014-02-05 11:26:55,886 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.cwtv.com/ has been found.
2014-02-05 11:26:55,886 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.foodnetwork.co.uk/?omnisource=gid_uk has been found.
2014-02-05 11:26:55,887 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.myp2p-eu.net/p/other-sport-myp2p.html has been found.
2014-02-05 11:27:55,888 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www7.aoso.ru/2012/11/2.html has been found.
2014-02-05 11:27:55,888 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www7.aoso.ru/2012/11/1.html has been found.
2014-02-05 11:27:55,894 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.cwtv.com/ has been found.
2014-02-05 11:27:55,894 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.foodnetwork.co.uk/?omnisource=gid_uk has been found.
2014-02-05 11:27:55,895 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.myp2p-eu.net/p/other-sport-myp2p.html has been found.
2014-02-05 11:28:55,895 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www7.aoso.ru/2012/11/2.html has been found.
2014-02-05 11:28:55,895 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www7.aoso.ru/2012/11/1.html has been found.
2014-02-05 11:28:55,904 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.cwtv.com/ has been found.
2014-02-05 11:28:55,904 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.foodnetwork.co.uk/?omnisource=gid_uk has been found.
2014-02-05 11:28:55,905 WARN [FeedUpdaterThread] An error occured while trying to parse an online resouce requiring a plugin, provide the plugin or remove the resource: No plugin for web resource http://www.myp2p-eu.net/p/other-sport-myp2p.html has been found.
If I want to stream something off the net, do I have to find a plugin before I do anything else? But, if so, why does the NASA one work without a plugin?
I'm now beginning to understand that the foodnetwork plugin doesn't work, and the cwtv plugin isn't available in the UK. I presume that I must search the Available Plugins thread for the aoso streams, and request them if they aren't there.
Is this right?
The You Tube wicki is wicked!
Users browsing this forum: Baidu [Spider] and 31 guests
