Serviio Doesn't Recognize some avi files
ablib
Post Sat Feb 08, 2014 6:29 am
I have two avi files in library that recognize and play fine.
However I have some avi's that Serviio just doesn't recognize. They play fine on my PC so they do not appear corrupted.
I followed the instructions here:
viewtopic.php?f=5&t=38
And I came to step 5 where I need to locate the FFmpeg executable. I did that, double clicked it, and the black command prompt box comes up then quickly disappears. I'm not sure where I'm supposed to type the ffmpeg.exe -i "<your_file_location>" command.
Post Sat Feb 08, 2014 9:58 am
Re: Serviio Doesn't Recognize some avi files
ablib wrote: I'm not sure where I'm supposed to type the ffmpeg.exe -i "<your_file_location>" command.
For windows OS, on a windows terminal : viewtopic.php?f=5&t=960
ablib
Post Sun Feb 09, 2014 3:56 am
Thank you.
Here are the results:
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Windows\System32>cd "\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i "E:\Movies\5 - 4 a.m. to 5 a.m..avi"
Input #0, avi, from 'E:\Movies\5 - 4 a.m. to 5 a.m..avi':
encoder : VirtualDubMod 1.5.4.1 (build 2178/release)
IAS1 : English
Duration: 00:41:54.05, start: 0.000000, bitrate: 1168 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv
420p, 720x416 [SAR 1:1 DAR 45:26], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16p, 110 k
b/s
Post Mon Feb 10, 2014 10:35 pm
Are they added to the library? (check the log or mediaBrowser)
Users browsing this forum: Google [Bot] and 191 guests
