Series artwork
Lunatixz
Post Tue Feb 11, 2014 1:56 am
Series artwork
I'm sure this has been covered, but I was unable to find a clear answer...
My series folders are missing artwork in mediabrowser. Movies show fine, but not TV Shows... What can I do to fix this?
Post Tue Feb 11, 2014 10:10 am
Re: Series artwork
Are ou going through Series category? What metadata source are you using?
Lunatixz
Post Tue Feb 11, 2014 4:58 pm
Re: Series artwork
I'm going to video/series, and don't see any artwork. Using xbmc.nfo as a meta source.
Post Wed Feb 12, 2014 5:14 pm
Re: Series artwork
Can you post your show.nfo file? Also is there a (hidden?) image representing the show cover? If so, where is it (e.g. in the same folder as show.nfo, in the same folder as the episodes, etc)?
Lunatixz
Post Thu Feb 13, 2014 12:15 am
Re: Series artwork
<tvshow xsd="http://www.w3.org/2001/XMLSchema" xsi="http://www.w3.org/2001/XMLSchema-instance">
  <title>10 Items Or Less</title>
  <rating>7.4</rating>
  <plot>10 Items Or Less stars John Lehr (Memron) as a struggling New York City businessman who moves home to take over the family supermarket following the death of his father. This scripted and improvised half-hour comedy series comes from the creators of the mockumentary Memron. The show is set in the fictional supermarket known as Greens &amp; Grains which is 'located' at 5th Street and Tiberius. The following is a character guide: Leslie Pool is the owner/manager of G&amp;G. Yolanda Nelson works in the produce department. Ingrid Wakowski is in customer service. Todd Sykes works in the meat department. Carl Dawson is a stockboy. Richard Mednick works as a cashier, while Buchwald Washington is a bagger.</plot>
  <episodeguide>
    <url>http://thetvdb.com/api/9DAF49C96CBF8DAC/series/79599/all/en.zip</url>
  </episodeguide>
  <episodeguideurl>http://thetvdb.com/api/9DAF49C96CBF8DAC/series/79599/all/en.zip</episodeguideurl>
  <mpaa>TV-PG</mpaa>
  <id>79599</id>
  <genre>Comedy</genre>
  <premiered>2006-11-27</premiered>
  <studio>TBS Superstation</studio>
  <actor>
    <name>Jr.</name>
    <role />
    <thumb />
  </actor>
  <actor>
    <name>Chris Payne Gilbert</name>
    <role />
    <thumb />
  </actor>
  <actor>
    <name>Greg Davis</name>
    <role />
    <thumb />
  </actor>
  <actor>
    <name>Jennifer Elise Cox</name>
    <role />
    <thumb />
  </actor>
  <actor>
    <name>John Lehr</name>
    <role />
    <thumb />
  </actor>
  <actor>
    <name>Kristen Gronfield</name>
    <role />
    <thumb />
  </actor>
  <actor>
    <name>Robert Clendenin</name>
    <role />
    <thumb />
  </actor>
  <actor>
    <name>Roberta Valderrama</name>
    <role />
    <thumb />
  </actor>
</tvshow>
Can you tell me what files serviio uses for artwork for movies and tv? does it look for a folder.jpg?
Post Thu Feb 13, 2014 8:04 pm
Re: Series artwork
For video files it uses files described here (Local Cover): http://serviio.org/index.php?option=com ... icle&id=12
I'll try to add season mapping for the future.
Post Thu Feb 13, 2014 10:34 pm
Re: Series artwork
So I assume it's folder.jpg or poster.jpg which is the image for the Series (not season)?
