Can't see files on Windows Server 2008/NAS
Any ideas?
npuser wrote:how are the folders mounted? Serviio works well if you use UNC path instead of mounted drives. If you are using UNC then a log file is in order; that will tell you the whole story.
http://serviio.org/component/content/article?id=21#q5
NPuser
2014-02-15 10:29:45,891 INFO [MediaServer] ------------------------------------------------------------------------
2014-02-15 10:29:45,892 INFO [MediaServer] Serviio DLNA media streaming server v 1.4 (rev. c307c4dd528d)
2014-02-15 10:29:45,892 INFO [MediaServer] Petr Nejedly 2009-2013
2014-02-15 10:29:45,892 INFO [MediaServer] http://www.serviio.org
2014-02-15 10:29:45,892 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2014-02-15 10:29:45,893 INFO [MediaServer] OS Windows Server 2008 R2 amd64 6.1
2014-02-15 10:29:45,893 INFO [MediaServer] File encoding: windows-1252
2014-02-15 10:29:45,906 INFO [MediaServer] Headless mode enabled: true
2014-02-15 10:29:45,907 INFO [MediaServer] User: ZOOSTORM$
2014-02-15 10:29:45,907 INFO [MediaServer] User home dir: C:\
2014-02-15 10:29:45,907 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2014-02-15 10:29:45,907 INFO [MediaServer] ------------------------------------------------------------------------
2014-02-15 10:29:46,410 INFO [WebServer] Socket buffer set to 65535 bytes
2014-02-15 10:29:46,436 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-02-15 10:29:46,738 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-02-15 10:29:46,739 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-02-15 10:29:46,770 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-02-15 10:30:03,451 INFO [DBSchemaUpdateExecutor] Updating DB schema
2014-02-15 10:30:37,562 INFO [MediaServer] ------------------------------------------------------------------------
2014-02-15 10:30:37,564 INFO [MediaServer] Serviio DLNA media streaming server v 1.4 (rev. c307c4dd528d)
2014-02-15 10:30:37,564 INFO [MediaServer] Petr Nejedly 2009-2013
2014-02-15 10:30:37,564 INFO [MediaServer] http://www.serviio.org
2014-02-15 10:30:37,564 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2014-02-15 10:30:37,564 INFO [MediaServer] OS Windows Server 2008 R2 amd64 6.1
2014-02-15 10:30:37,564 INFO [MediaServer] File encoding: windows-1252
2014-02-15 10:30:37,565 INFO [MediaServer] Headless mode enabled: true
2014-02-15 10:30:37,565 INFO [MediaServer] User: Ian Manning
2014-02-15 10:30:37,565 INFO [MediaServer] User home dir: C:\Users\Ian Manning
2014-02-15 10:30:37,565 INFO [MediaServer] Temp dir: C:\Users\IANMAN~1\AppData\Local\Temp\
2014-02-15 10:30:37,565 INFO [MediaServer] ------------------------------------------------------------------------
2014-02-15 10:30:37,838 INFO [WebServer] Socket buffer set to 65535 bytes
2014-02-15 10:30:37,840 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-02-15 10:30:37,941 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-02-15 10:30:37,941 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-02-15 10:30:37,976 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-02-15 10:30:48,397 INFO [DBSchemaUpdateExecutor] Updating DB schema
2014-02-15 10:30:49,434 INFO [ServiioConsole] Initializing Serviio Console
2014-02-15 10:30:49,485 INFO [ServiioConsole] Starting Serviio Console
2014-02-15 10:30:53,279 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-02-15 10:30:53,599 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2014-02-15 10:30:54,290 INFO [Device] Created UPnP Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.4
2014-02-15 10:30:55,457 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2014-02-15 10:30:55,506 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2014-02-15 10:30:57,190 INFO [MediaServer] ------------------------------------------------------------------------
2014-02-15 10:30:57,190 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2014-02-15 10:30:58,537 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2014-02-15 10:30:58,762 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2014-02-15 10:30:58,796 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2014-02-15 10:30:58,811 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2014-02-15 10:30:58,825 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2014-02-15 10:30:58,830 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2014-02-15 10:30:58,837 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2014-02-15 10:30:58,846 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2014-02-15 10:30:58,849 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2014-02-15 10:30:58,852 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2014-02-15 10:30:58,895 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2014-02-15 10:30:58,905 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2014-02-15 10:30:58,910 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2014-02-15 10:30:58,936 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2014-02-15 10:30:58,939 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2014-02-15 10:30:58,941 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2014-02-15 10:30:58,944 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2014-02-15 10:30:58,966 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2014-02-15 10:30:58,968 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2014-02-15 10:30:58,970 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2014-02-15 10:30:58,972 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2014-02-15 10:30:58,974 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2014-02-15 10:30:58,977 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2014-02-15 10:30:58,979 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2014-02-15 10:30:58,982 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2014-02-15 10:30:58,984 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2014-02-15 10:30:58,986 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2014-02-15 10:30:58,990 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2014-02-15 10:30:58,994 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2014-02-15 10:30:58,996 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2014-02-15 10:30:58,998 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2014-02-15 10:30:59,000 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2014-02-15 10:30:59,002 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2014-02-15 10:30:59,005 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2014-02-15 10:30:59,007 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2014-02-15 10:30:59,009 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2014-02-15 10:30:59,014 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2014-02-15 10:30:59,017 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2014-02-15 10:30:59,019 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2014-02-15 10:30:59,021 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2014-02-15 10:30:59,023 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2014-02-15 10:30:59,026 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2014-02-15 10:30:59,028 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2014-02-15 10:30:59,176 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2014-02-15 10:30:59,181 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2014-02-15 10:30:59,184 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2014-02-15 10:30:59,187 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2014-02-15 10:30:59,190 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2014-02-15 10:30:59,192 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2014-02-15 10:30:59,195 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2014-02-15 10:30:59,198 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2014-02-15 10:30:59,237 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2014-02-15 10:30:59,238 INFO [PluginCompilerThread] Started looking for plugins
2014-02-15 10:30:59,298 INFO [UpdateChecker] Checking if a new version is available
2014-02-15 10:30:59,520 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version N-54096-ge41bf19 Copyright (c) 2000-2013 the FFmpeg developers
2014-02-15 10:30:59,710 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-02-15 10:30:59,761 INFO [WebServer] WebServer starting on port 8895
2014-02-15 10:31:00,329 INFO [Device] Updated bound IP address of Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.4
2014-02-15 10:31:00,356 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-02-15 10:31:00,357 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-02-15 10:31:00,362 INFO [EventDispatcher] Starting EventDispatcher
2014-02-15 10:31:00,374 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2014-02-15 10:31:00,519 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)) and address 192.168.1.4, timeout = 0
2014-02-15 10:31:00,540 INFO [RendererSearchSender] Searching for Renderer devices
2014-02-15 10:31:00,897 INFO [RendererManager] Stored a new renderer: uuid='31e2437a-8512-b131-6c48-626875aa1be0', name = 'Squeezebox Boom', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:31:00,999 INFO [RendererManager] Stored a new renderer: uuid='4d454930-0300-1000-8000-cc7ee7bcccbb', name = 'BD/DVD Recorder', ipAddress='192.168.1.127', profile = '1'
2014-02-15 10:31:01,461 INFO [RendererManager] Stored a new renderer: uuid='bfb0069c-5706-9cb9-c40f-9c0957b95ee7', name = 'TX-NR515', ipAddress='192.168.1.123', profile = '1'
2014-02-15 10:31:01,656 INFO [RendererManager] Stored a new renderer: uuid='1f42c989-5331-5ea8-6a8b-9c8c4deb2a67', name = 'SqueezePlay', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:31:01,749 INFO [RendererManager] Stored a new renderer: uuid='c0c1a91e-088a-4232-8ab8-428c0655946e', name = 'Windows Media Player', ipAddress='192.168.1.5', profile = '1'
2014-02-15 10:31:01,904 INFO [RendererManager] Stored a new renderer: uuid='31e2437a-8512-b131-6c48-626875aa1be0', name = 'Squeezebox Boom', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:31:02,412 INFO [RendererManager] Stored a new renderer: uuid='152ddd1e-8691-46d6-9577-67a779005cfc', name = 'Unrecognized device', ipAddress='192.168.1.230', profile = '1'
2014-02-15 10:31:02,420 INFO [RendererManager] Stored a new renderer: uuid='fea6194f-850b-5cb3-316f-bc3fd2a9f864', name = 'Squeezebox 3', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:31:02,682 INFO [RendererManager] Stored a new renderer: uuid='3e9451cb-5b3d-d5b3-8c92-1133dc6f4ad1', name = 'Squeezebox Boom', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:31:02,840 INFO [RendererManager] Stored a new renderer: uuid='1f42c989-5331-5ea8-6a8b-9c8c4deb2a67', name = 'SqueezePlay', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:31:03,023 INFO [RendererManager] Stored a new renderer: uuid='3e9451cb-5b3d-d5b3-8c92-1133dc6f4ad1', name = 'Squeezebox Boom', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:31:03,175 INFO [RendererManager] Stored a new renderer: uuid='fea6194f-850b-5cb3-316f-bc3fd2a9f864', name = 'Squeezebox 3', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:31:03,330 INFO [RendererManager] Stored a new renderer: uuid='3e9451cb-5b3d-d5b3-8c92-1133dc6f4ad1', name = 'Squeezebox Boom', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:31:03,416 INFO [RendererManager] Stored a new renderer: uuid='151e8369-3db7-40d4-8f4b-3fff3c707a78', name = 'Windows Media Player', ipAddress='192.168.1.230', profile = '1'
2014-02-15 10:31:03,570 INFO [RendererManager] Stored a new renderer: uuid='fea6194f-850b-5cb3-316f-bc3fd2a9f864', name = 'Squeezebox 3', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:31:03,697 INFO [RendererManager] Stored a new renderer: uuid='1f42c989-5331-5ea8-6a8b-9c8c4deb2a67', name = 'SqueezePlay', ipAddress='192.168.1.4', profile = '1'
2014-02-15 10:33:18,256 INFO [Messages] Loaded console message bundle for locale: en
2014-02-15 10:33:28,050 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2014-02-15 10:33:32,078 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2014-02-15 10:33:37,844 INFO [FeedUpdaterThread] Started looking for information about online resources
2014-02-15 10:33:37,847 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-02-15 10:33:37,849 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-02-15 10:33:37,850 INFO [PlaylistMaintainerThread] Started looking playlist changes
2014-02-15 11:03:19,224 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-02-15 11:03:19,362 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-02-15 11:03:19,424 INFO [PlaylistMaintainerThread] Finished looking for playlist changes
2014-02-15 11:03:19,613 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-02-15 11:03:19,614 INFO [PlaylistMaintainerThread] Started looking playlist changes
2014-02-15 11:03:19,614 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-02-15 11:03:27,861 INFO [SearchManager] Starting up search engine
2014-02-15 11:03:31,049 INFO [LibraryAdditionsCheckerThread] Added file '20131224_210030.jpg' (title: 20131224_210030) to Library
2014-02-15 11:03:31,155 WARN [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
org.serviio.db.dao.PersistenceException: Cannot mark Repository with id 1 as scanned
at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:173)
at org.serviio.library.local.service.RepositoryService.markRepositoryAsScanned(RepositoryService.java:114)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:84)
Caused by: java.sql.SQLNonTransientConnectionException: Connection closed by unknown interrupt.
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeLargeUpdate(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:171)
... 2 more
Caused by: java.sql.SQLException: Connection closed by unknown interrupt.
... 13 more
Caused by: ERROR 08000: Connection closed by unknown interrupt.
at org.apache.derby.iapi.util.InterruptStatus.setInterrupted(Unknown Source)
at org.apache.derby.iapi.util.InterruptStatus.throwIf(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.checkCancellationFlag(Unknown Source)
at org.apache.derby.impl.sql.execute.TableScanResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.IndexRowToBaseRowResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.NormalizeResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.DMLWriteResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.UpdateResultSet.collectAffectedRows(Unknown Source)
at org.apache.derby.impl.sql.execute.UpdateResultSet.open(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
... 7 more
2014-02-15 11:03:31,215 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-02-15 11:03:31,261 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-02-15 11:03:31,361 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-02-15 11:03:31,362 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-02-15 11:03:33,049 INFO [LibraryAdditionsCheckerThread] Added file '20131224_225816.jpg' (title: 20131224_225816) to Library
2014-02-15 11:03:34,999 INFO [LibraryAdditionsCheckerThread] Added file '20131225_151841.jpg' (title: 20131225_151841) to Library
2014-02-15 11:03:36,522 INFO [LibraryAdditionsCheckerThread] Added file '20131225_174901.jpg' (title: 20131225_174901) to Library
2014-02-15 11:03:38,302 INFO [LibraryAdditionsCheckerThread] Added file '20131225_210638.jpg' (title: 20131225_210638) to Library
2014-02-15 11:04:01,556 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file 2003 Richmond Garden.avi [VideoDescription [type=FILM, names=[2003 richmond garden, null], year=null, season=null, episode=null]]
2014-02-15 11:04:02,667 INFO [LibraryAdditionsCheckerThread] Added file '2003 Richmond Garden.avi' (title: 2003 Richmond Garden) to Library
2014-02-15 11:04:05,093 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file 2008 Malaysia & Phuket.mp4 [VideoDescription [type=FILM, names=[2008 malaysia & phuket, null], year=null, season=null, episode=null]]
2014-02-15 11:04:05,785 INFO [LibraryAdditionsCheckerThread] Added file '2008 Malaysia & Phuket.mp4' (title: 2008 Malaysia & Phuket) to Library
2014-02-15 11:19:40,826 WARN [EventDispatcher] Error 400 received from event subscriber
npuser wrote:
Try updating java to 1.7.0_51 (i think).
It stills look like permission issue. User serviio running unable to read the file/folder in UNC. You could try creating/adding user in windows server similar to NAS with same username and password and run serviio under that account.
NPuser
Users browsing this forum: Baidu [Spider] and 22 guests
