Serviiogo "failed to connect"
roastedkiwi
Post Tue Mar 04, 2014 1:35 am
Hey all , Im stumped at the mo with serviio and serviiogo as they wont connect !! serviio seems to be running fine BUT serviiogo on Kaiser baas and galaxy 4
cant connect.. I have latest java 7 installed and have tried a number of solution from forums with no luck. any ideas?? cheers
Post Tue Mar 04, 2014 7:35 am
Re: Serviiogo "failed to connect"
What settins have you configured in the Serviio Console -> Remote tab.
If you had entered something into the 'External Address' box, ServiiGo will use that automatically, so it might be worth removing it first, then re-adding the Server in ServiiGo so that it connects to the server's local ip address. Once you have confirm that is working, then go on to setting up remote access.
