Series poster not showing
Betelgeuse
Post Wed Mar 26, 2014 12:07 pm
When I chose Series in Mediabrowser only about 50% show the corresponding art for the serie.
If I chose Folders and chose my Series folder, only 2 out of 64 folders shows the folder art.
I use Media Companion for scraping movies/series, and it creates nfo files and art compatible with Xbmc.
How does Serviio chose which art to show? Is it from the nfo file or image files located in the directory?
Post Fri Mar 28, 2014 12:48 am
Re: Series poster not showing
In Series view it uses the metadata (although I think it only works for online sources currently).
For Folders category it just uses thumbnail of a random file in the folder.
Betelgeuse
Post Fri Mar 28, 2014 9:03 am
I think the poster handling is something should be worked on. It is very convenient and nice looking to have the right file/series poster showing. The "folder picture overlay" that shows on top of posters as it do now is a great feature. It differs folders and files clearly.
Users browsing this forum: Google [Bot] and 26 guests
