Service not starting
Jfrm
Post Sun Apr 06, 2014 8:10 am
After last update Serviio Service is not starting automatically and if I initiate it from Services Admin panel (using win 7) it start and then close in 10 seconds.
Any clue?
Here is my log.
2014-04-06 10:07:11,301 INFO [MediaServer] ------------------------------------------------------------------------
2014-04-06 10:07:11,302 INFO [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f)
2014-04-06 10:07:11,303 INFO [MediaServer] Petr Nejedly 2009-2014
2014-04-06 10:07:11,303 INFO [MediaServer] http://www.serviio.org
2014-04-06 10:07:11,303 INFO [MediaServer] Java 1.7.0_51-Oracle Corporation
2014-04-06 10:07:11,303 INFO [MediaServer] OS Windows 7 x86 6.1
2014-04-06 10:07:11,303 INFO [MediaServer] File encoding: windows-1252
2014-04-06 10:07:11,304 INFO [MediaServer] Headless mode enabled: true
2014-04-06 10:07:11,304 INFO [MediaServer] User: SERVER$
2014-04-06 10:07:11,304 INFO [MediaServer] User home dir: C:\
2014-04-06 10:07:11,304 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2014-04-06 10:07:11,304 INFO [MediaServer] ------------------------------------------------------------------------
2014-04-06 10:07:11,532 INFO [WebServer] Socket buffer set to 65535 bytes
2014-04-06 10:07:11,535 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-04-06 10:07:11,610 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-04-06 10:07:11,611 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-04-06 10:07:11,636 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-04-06 10:07:11,651 INFO [DatabaseManager] Using DERBY database language
2014-04-06 10:07:13,093 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@12833ff, see the next exception for details.
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.Driver20.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(Unknown Source)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:59)
at org.serviio.MediaServer.main(MediaServer.java:116)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@12833ff, see the next exception for details.
... 26 more
Caused by: java.sql.SQLException: Java exception: ': java.lang.NullPointerException'.
at org.apache.derby.impl.jdbc.Util.javaException(Unknown Source)
... 23 more
Caused by: java.lang.NullPointerException
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openDroppedContainer(Unknown Source)
at org.apache.derby.impl.store.raw.xact.Xact.openDroppedContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.PageBasicOperation.findpage(Unknown Source)
at org.apache.derby.impl.store.raw.data.PageBasicOperation.needsRedo(Unknown Source)
at org.apache.derby.impl.store.raw.log.FileLogger.redo(Unknown Source)
at org.apache.derby.impl.store.raw.log.LogToFile.recover(Unknown Source)
at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
... 23 more
2014-04-06 10:07:15,099 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
Post Tue Apr 08, 2014 12:38 pm
Re: Service not starting
Looks like corrupted database, or access rights to the database. Try to do a clean install.
Users browsing this forum: Baidu [Spider] and 28 guests
