All Movies do not show up.
RedPlague
Post Sun Mar 30, 2014 1:08 pm
Hello everyone.
I have a problem. When I look at my movies on my playstation 3 and Samsung TV, I do not see the movies that start with T thru Z. I set the scan time to 1440 Minutes which is 24 hours, thinking that it is because I have 6 TB of Movies on my two drive. One drive contains movies from A to X and the other contains movies A to Z.
Now I wonder if this a because I'm using the Free version.
RedPlague
Post Sun Mar 30, 2014 1:09 pm
Re: All Movies do not show up.
Sorry, I didn't finish my post.
Does anyone have any thoughts on the issue?
Post Sun Mar 30, 2014 11:04 pm
You don't set scan time in the console, you set the interval between scans.
It might take many hours to scan your library, if it's huge.
RedPlague
Post Mon Apr 14, 2014 8:39 pm
OK. I have add another movie that has a title starting with S. It showed up in about 15 minutes after I started the scan manually. This leads me to believe that my media is not that big. Even thou I have it set to scan every 1440 minutes. It made it through the movie files and down to the title starting with S in 15 minutes, it should have made it all the way threw in under an hour, if that long.
