Xbox streaming tv broken
grolschie
Post Wed Feb 06, 2013 11:39 pm
Re: Xbox streaming tv broken
zip wrote:it means the XBox encountered something it doesn't like and closed the connection
Sorry, I'm still gnawing at this bone. :D Respectfully, it seems that I am not alone with this. Could I perhaps capture this with wireshark or something and send it to you please?
grolschie
Post Thu Feb 07, 2013 4:38 am
I contacted Xbox support on Twitter today about this error. They couldn't provide any more info on the error, but I was told that the error seems to suggest that the connection was interrupted.
I also asked if too long a delay before receiving any data would cause the System Video Player to time out, and was told that a delay in response could possibly cause this error. Maybe the Serviio would need to send some blank video or something to the Xbox immediately, while the stream is loading and beginning to transcode?
grolschie
Post Sun Feb 17, 2013 10:15 pm
Just an update. I have turned my wifi router off and connected via ethernet. Serviio's internet video streaming is still broken on the Xbox.
grolschie
Post Wed Feb 27, 2013 5:05 am
Xbox support tweeted me this page:
http://support.xbox.com/en-US/xbox-360/audio-video-setup-and-use/video-playback-status-codes
It says:
53-C00DF237
53-C00DF238
The network connection was closed.
Make sure that your computer is turned on, connected to the network, and running media-sharing software.
So I wonder, does that mean that the Xbox thinks that Serviio has stopped sending it data then?
slyguy42o
Post Wed Feb 27, 2013 4:47 pm
sorry if I missed this in the thread, but what content are you trying to stream? The only content that seems to work for me is shows off the hulu plugin, pretty much all others don't work on the xbox for me.
grolschie
Post Wed Feb 27, 2013 7:05 pm
I have problems streaming mostly AppleHTTP streams e.g.
  • http://ebuios-i.akamaihd.net/hls/live/201262/sample/iphone/test.m3u8
  • http://srv1.viiideo.gr:1935/hellasonmedia/mp4:neatv/playlist.m3u8
  • http://eco.caststream.net:1935/tv100/tv100/playlist.m3u8"
  • http://srv1.viiideo.gr:1935/hellasonmedia/mp4:tvcreta/playlist.m3u8
This is with the latest beta, which seems to have significantly improved streaming video with the Xbox.
I also have exceptions, such as one .m3u8 stream which does seem to work. And also an rtmp stream that doesn't work with the Xbox.
grolschie
Post Fri Apr 18, 2014 1:36 am
Update. Streaming still broken on Xbox 360 with Serviio 1.4.1.1. I am now running Debian Linux on the same PC and have added streams manually to Serviio (previously I used the LiveFeeds plugin). Still the same error.
Previous
