switch of autostart
telex
Post Wed Jan 02, 2013 5:48 pm
switch of autostart
how can I switch off windows serviio autostart?
Post Wed Jan 02, 2013 10:03 pm
Re: switch of autostart
If you mean the service then change the service to manual start in the Services management console. If you mean the console, remove it from the Startup Windows Start menu.
telex
Post Wed Jan 02, 2013 10:12 pm
where in Win7? start menu I know from XP but Win7?
and where in the console , cant find "manual" ...
blokey
Post Wed Jan 02, 2013 10:27 pm
The background Serviio Service (the actual server) is found in services.msc (run this in the search box). Set the Serviio service to manual.
The Serviio Console (The frontend you see) is found in the Startup folder under All Programs. Delete this and the console won't start.
Hope that helps
telex
Post Thu Jan 03, 2013 7:11 pm
can I use "msconfig" to disable both?
msconfig--> services
on autostart menu is no entry...because I disabled on msconfig ---> systemstart
theobald
Post Sun Mar 17, 2013 11:40 pm
I am using Windows 8 and do not find a possibility to disable the autostart of "ServiioService.exe" (I am able to disable the autostart of the console)
What to do? "ServiioService.exe" is not listed up in Task-Manager --> Autostart. I do not know where to find the "Services management console" zip mentioned in his post. Thanks for your help!
SpecialK
Post Mon May 12, 2014 12:45 pm
I am running Windows 8.1 and have the Serviio service set to Manual, however whenever I start-up my computer it shows as "Running". Is there another service that would force Serviio to begin running?
Post Mon May 12, 2014 9:03 pm
no.
Users browsing this forum: Baidu [Spider] and 33 guests
