remote console linux
phn2
Post Sun May 11, 2014 8:14 pm
Having problems using console on my remote Linux mint machine after reinstall of OS.
Use to be able to use ver. 1.31 connecting to server with newest version.
Have changed javaopts in bin/console.sh, but nothing happens when trying to start.
Post Sun May 11, 2014 8:55 pm
Re: remote console linux
You need the same version of the console and the server
phn2
Post Mon May 12, 2014 4:13 am
Yes i have that. Still no luck
Post Mon May 12, 2014 8:14 pm
where is the server and where is the console?
phn2
Post Tue May 13, 2014 5:47 am
server is on a Stativ adress, works fine as serving media to hole house. Server OS is turnkey Linux, console server OS is Linux mint. I have edited Java opts on serverside.
Post Tue May 13, 2014 6:10 pm
you have to edit then on the console side, to tell the console where is the server you want to connect to
phn2
Post Tue May 13, 2014 7:06 pm
Yes thats what I Mean, java opst With
My serveradress
JAVA_OPTS="-Dserviio.home=$SERVIIO_CONSOLE_HOME -Djava.net.preferIPv4Stack=true -Dserviio.remoteHost=192.168.2.10"
looks ok?
by the way, the link on your site about setting up console > remote server is dead.
If you are having difficulties to connecting to Serviio on Linux, this article on forum might help.
Post Tue May 13, 2014 8:33 pm
It looks fine. I assume 192.168.2.10 is the server's IP.
Do you have java installed on the client? is there something in the console log?
phn2
Post Wed May 14, 2014 5:13 am
Yes, openjdk-7-jre is installed. Wheres the location of console-log, couldnt find it.
Post Thu May 15, 2014 6:19 pm
serviio.log under log folder in the console installation
phn2
Post Fri May 16, 2014 2:23 am
per bin # ls
serviio-console.sh serviio.sh
per bin # bash serviio-console.sh
Error: Could not find or load main class filer.serviio-1.4.1.2
per bin #
is what it says when trying to start in terminal. No log file...
