Downmixing MKV 6 Channel Audio to Stereo
konrad
Post Thu May 15, 2014 5:01 pm
Is there a way to modify a profile ( specifically the Windows8/RT ) , to downmix 6 channel to stereo ? The file I am concerned with is an .mkv file with six channel audio AC-3 and I would like to be able to have serviio convert or transcode it down to stereo to make it playable on my system. Many thanks.
Post Thu May 15, 2014 6:23 pm
Re: Downmixing MKV 6 Channel Audio to Stereo
If the file is transcoded, check the Transcoding tab, there is a option for it.
konrad
Post Fri May 16, 2014 7:51 pm
Thought I'd post the solution I discovered for the problem I had with an .avi (actually a .mkv file) , that was playing video but no audio on a Roku 2. Originally I was using the Roku profile , but it would not play my .flv files.... so I switched profiles to the Windows 8/RT profile and that cured the .flv problem. Then I aquired a file that had a .avi extension but internally (checked with MediaInfo) was a .mkv file. Video would play fine on the Roku but no audio. Changed extension to .mkv....still no audio. Since the audio was 6 channel AC3 , I thought maybe this was the problem. The suggestion to select downmix to stereo , (on the transcoding tab in the Serviio console) , did nothing. Then I selected surround sound on the Roku audio settings and voila!....I got sound from the .mkv file...but my Roku re-booted itself after a few seconds of playing the file , so I did not feel too comfortable with that solution. (Switched the Roku back to stereo!) Finally , I edited the profiles.xml file from this:
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="320">
<Matches container="matroska" aCodec="dts-hd" />
<Matches container="matroska" aCodec="vorbis" />
<Matches container="ogg" vCodec="mpeg4" />
<Matches container="mp4" aCodec="lpcm" />
To this:
<Video targetContainer="mpegts" targetACodec="mp3" forceStereo="true">
And that enabled the Roku to play the .mkv file (with audio) in stereo. This may help someone with similar problems.
Users browsing this forum: Google [Bot] and 25 guests
