[SOLVED] Fast Forward and Rewind
railfrog
Post Tue Apr 09, 2013 11:16 am
Hi
Just looking for a bit of information.
Most of the videos I watch in .MKV format do not let me either fast forward or rewind. Pause always works no matter what.
The files are on a Win7 64 bit machine which is attached to the same LAN as a LG HB405SU BD Player which the files are played on and then routed through High Def lead to a LG TV.
What I want to know is this: What enables the file to fast forward and rewind?
Is it the way the original file was put in to the .MKV container?
Is it the streaming from PC to BD player?
I don't think the files are transcoded but could it be that?
Post Tue Apr 09, 2013 1:09 pm
Re: Fast Forward and Rewind
Its a function of the player, which then sends a signal to Serviio and Serviio serves up from the point requested
slyguy42o
Post Tue Apr 09, 2013 2:29 pm
what profile are you using for your device?
railfrog
Post Tue Apr 09, 2013 6:14 pm
jhb50 wrote:Its a function of the player, which then sends a signal to Serviio and Serviio serves up from the point requested
Never crossed my mind that it would be the player.
slyguy42o wrote:what profile are you using for your device?
The Generic DLNA Profile.
slyguy42o
Post Tue Apr 09, 2013 8:23 pm
try switching the profile to "LG" and see if it helps.
railfrog
Post Sun Apr 14, 2013 10:18 pm
slyguy42o wrote:try switching the profile to "LG" and see if it helps.
Tried that and still no joy.
Some files work and others do not.
slyguy42o
Post Mon Apr 15, 2013 6:12 pm
FF and RW are determined by what formats your player supports. in alot of cases where you have this issue it means that the format of the video that it is being transcoded to does not have seek support on your player. The profile may need to be tweaked in order to support FF / RW
The Generic profile does not transcode so anything that plays using this profile is supported natively by your playback device.
railfrog
Post Mon Apr 15, 2013 10:27 pm
slyguy42o wrote:The profile may need to be tweaked in order to support FF / RW
Can you point me in the right direction of where I would start to do this.
slyguy42o
Post Tue Apr 16, 2013 2:44 pm
railfrog
Post Tue May 20, 2014 10:28 pm
Well it seems like I was right from the beginning.
It is the way that the .MKV file was "put together" in the first place.
See this --> http://forum.serviio.org/viewtopic.php?f=10&t=4315
I did this in mkvmerge and now those files are able to F/F and R/W. :D
Users browsing this forum: No registered users and 53 guests
