Console
• Page 1 of 1
Re: Console
Just get the Windows installer in select to install only the Console. The setup remote console as per FAQ
Petr
Help translate Serviio
Re: Console
zip wrote:Just get the Windows installer in select to install only the Console. The setup remote console as per FAQ
John.
Re: Console
I have done this but nothing happens, the service is process is running in the background but I see nothing. The log is the following. Both versions are the same 1.4.1.2
ServiioConsole.exe.vmoptions has this as instructed - -Dserviio.remoteHost=192.168.0.20
2014-07-03 21:50:06,400 INFO [ServiioConsole] Initializing Serviio Console
2014-07-03 21:50:06,463 INFO [ServiioConsole] Starting Serviio Console
2014-07-03 21:50:06,807 INFO [ServiioConsole] Connecting to Serviio REST on 192.168.0.20:23423
2014-07-03 21:50:10,434 INFO [Messages] Loaded console message bundle for locale: en
Re: Console
Any ideas why the Windows console won't work?
John.
John.
Re: Console
It should open the console (add an icon in the task bar notification area)
Petr
Re: Console
zip wrote:It should open the console (add an icon in the task bar notification area)
It isn't, I see the process running in the background but nothing opens up to view.
Re: Console
Sometimes happens with some versions of java. Try to update java, and if it doesn't work, uninstall all Java and install it again.
Petr
Re: Console
zip wrote:Sometimes happens with some versions of java. Try to update java, and if it doesn't work, uninstall all Java and install it again.
Perfect. thanks again
John.
• Page 1 of 1
Users browsing this forum: Google [Bot] and 11 guests
