Problem with .sdp file created with QuickTime Broadcaster
grolschie
Post Wed Jul 16, 2014 9:30 pm
I am trying to use Serviio to add a stream from my Macbook that is using QuickTime Broadcaster and Soundflower. I have tried streaming without video and Serviio can see the stream but devices cannot play it. If I enable video then Serviio won't even accept the stream. The SDP file is located on my webpage, but contains only local IP addresses - thus will only work when accessed from my local network. The output of FFmpeg -i for this stream (with video enabled) is:
ffmpeg version 1.1.git Copyright (c) 2000-2013 the FFmpeg developers
  built on Mar 26 2014 12:15:04 with gcc 4.7 (Debian 4.7.2-5)
  configuration: --enable-gpl --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid
[sdp @ 0x9d05040] Could not find codec parameters for stream 1 (Video: h264, 640x480): unspecified pixel format
Consider increasing the value for the 'analyzeduration' and 'probesize' options
Input #0, sdp, from 'http://..deleted../stream.sdp':
    title           : QuickTime
  Duration: N/A, bitrate: N/A
    Stream #0:0: Audio: aac, 44100 Hz, stereo, fltp
    Stream #0:1: Video: h264, 640x480, 90k tbr, 90k tbn, 180k tbc
This is what's in the generated SDP file:
v=0
o=- 1 3315769473 IN IP4 127.0.0.0
s=QuickTime
t=0 0
a=range:npt=now-
a=isma-compliance:2,2.0,2
m=audio 5432 RTP/AVP 96
c=IN IP4 192.168.100.5
b=AS:125
a=rtpmap:96 mpeg4-generic/44100/2
a=fmtp:96 profile-level-id=15;mode=AAC-hbr;sizelength=13;indexlength=3;indexdeltalength=3;config=1210
a=mpeg4-esid:101
a=x-bufferdelay:3.000000
m=video 5434 RTP/AVP 97
b=AS:1372
a=rtpmap:97 H264/90000
a=fmtp:97 packetization-mode=1;profile-level-id=4D401E;sprop-parameter-sets=J01AHqkYFAe2ANQYBBrbCte98BA=,KN4JF6A=
a=mpeg4-esid:201
a=cliprect:0,0,480,640
a=framesize:97 640-480
The same file detects when set to Audio and then pressing "Check Stream URL" but not when setting it to Video and pressing "Check Stream URL".
Any tips please? All I want is to stream audio from my Macbook (but video will do also I need be) to DLNA devices. Other options cost a bit much for me to justify or require a newer version OS X than I have. Thanks.
Post Wed Jul 16, 2014 9:34 pm
Re: Problem with .sdp file created with QuickTime Broadcaste
SDP is not supported.
grolschie
Post Wed Jul 16, 2014 9:57 pm
Ok, thanks. Anyone got any audio streaming tips for Mac (besides Nicecast) that will work on OS X 10.6.8 please?
