Microsoft media player
mxdog
Post Fri Jul 04, 2014 2:24 pm
Has anyone figured out how to get windows media player 12 to work with Serviio? That is the default player that comes with windows 7 sp1 (and my systems are). It is funny that the media player can see the server just fine but fails to get file/folder/playlist information. I've found many posts that WMP 11 will work with some codec packs but I am finding nothing on getting WMP 12 to work. I have serviio running on a win server 2012 machine in a local domain and the systems I'm trying to connect from are all win7 sp1. If this is a non problem for others a little guidance on what I may be doing wrong would be most welcome.
SolihullRog
Post Wed Aug 06, 2014 7:55 am
Re: Microsoft media player
Are you still there?
I think you need the Windows Indexing service running on your PC, then you need to Windows Media Player where your media is. (In WMP > Organise >Manage Libraries).
Ask for more help if this gets you somewhere.
