console not open.
Dick_Serviio
Post Mon Aug 18, 2014 12:15 pm
console not open.
Installation teh first time the last version. It works great,but now i cannot connect the console (it is running). Nor i can open http://localhost:23424/mediabrowser. The message is "no webpage ".
Ik reinstall JAVA en Serviio after uninstallig.
Solution?
Lowlander
Post Tue Aug 26, 2014 3:39 pm
Re: console not open.
Unfortunately you do not provide too much information here. If Serviio works great, you should really be able to connect to it with the console - which is running - from the same machine.
I'd recommend you have a peek at zip's "READ BEFORE POSTING !!!" post in this forum, and if you don't find the solution in the resources listed there, please collect more information for us to assist you.
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
