Problem with 1.4.1.2 on Sony Bravia
kusnier
Post Mon Aug 25, 2014 8:26 pm
I've recently noticed strange behavior of Serviio 1.4.1.2 with two (different) Sony Bravia 2012 models, that was not there until recently both Serviio and Bravia firmware was updated.
After chosing Video from Sony and then Serviio in DLNA resources for first 4-5 minutes
- only some of the videos in direcories are visible (no clear pattern on that), and part of directories appear empty
- for thos 4-5 minutes first position after selecting Serviio I see is strangely "Images" as postion in list - altough from Bravia I've chosen Video DLNA resurces
After those 4-5 minutes postion Images is dissapearing and I can browse all movies directories on Serviio as it was before last updates.
Any idea what is causing this ?
Lowlander
Post Tue Aug 26, 2014 3:18 pm
Re: Problem with 1.4.1.2 on Sony Bravia
Nope. :(
But for a start, I'd recommend to remove all renderers from the device-list in Serviio's console (status tab) and to clear the server list on the TVs. There is a good chance things might return to normal behaviour after everybody has rediscovered each other. As soon as the TVs reappear in Serviio's status tab, you may want to make sure they are assigned to the correct (previous) profile.
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
kusnier
Post Sun Sep 28, 2014 7:36 pm
After few tries this didn't help, it's even getting worse. I can browse folder frombravia (videos). I see thumbnails, but none of movie is playing.
Is there pleace to download original 1.4 and older 1.3 versions ?
Post Mon Sep 29, 2014 7:00 am
Where movies are stored ? external HDD ? USB ?
Do you enabled automatic library refresh on serviio console ?
http://download.serviio.org/releases/se ... -setup.exe
kusnier
Post Tue Sep 30, 2014 9:12 pm
Everything is on main HDD, no externals/USB win 8.1
Automatic refresh is on - but it was on all the time from 1.1 version
I'll try to reinstall with older version.
Users browsing this forum: Google [Bot] and 35 guests
