How to add fileshares in Serviio on a Mac?
CryxDX2
Post Fri Oct 24, 2014 11:21 am
Hello Guys,
i am a little bit struck down.
finaly i install a Serviio Server on my MacMini, alwasy runs so far.
But only with local Drives (USB HDDs) if i want to connect a NAS to the Serviio Server, it shows me the bath, bot every time it adds a "/" or when i start the server from a folder than came the complete folderpath ( like "/user/documents/serviio/afp://..." and so an) but the Server does not touch the files in this folder. My music is in the NAS. When i Mount the NAS in MacOS then i could also add the drive over local options but it is the same issue that serviio does not see the files.
On my Windows Testlaptop it runs perfecly with the UNC Path but not on mac.
I would like to clear this issue because i like the easy settings and the webinterface.
And i would like buy the pro version, but only if i know how to setup the shared drives.
i hope some one can help me.
thanks so far.
CryxDX2
CryxDX2
Post Sat Oct 25, 2014 9:31 am
Re: How to add fileshares in Serviio on a Mac?
Ok i solve the problem.
it is poosible that the manual rescan crash when u at first add all folders from a NAS and Local drives and than start the scan.
I add the folder than scan, than add the next, step by step. this helps. and now all my 3 NAS and 3 USB drives are add with the content.
