Device list totally empty
Luckyfriend222
Post Wed Oct 29, 2014 9:01 pm
Hey guys
I have just installed a fresh copy of Fedora 18, installed Serviio, did an update, but still my problem will not go away.
I open up the console to Serviio, but the list is totally blank. There is nothing in there. The bound IP is set to Auto, which will use the em1. I have done this like a million times for other people, and litterally never had this issue.
Don't know why this will not work. Background info:
uname -r : 3.11.10-100.fc18.x86_64
ffmpeg: ffmpeg-1.0.8-1.fc18.x86_64
java: java-1.7.0-openjdk-1.7.0.60-2.4.3.0.fc18.x86_64
Detailed log:
2014-10-29 22:51:21,525 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2014-10-29 22:51:21,525 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2014-10-29 22:51:21,525 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2014-10-29 22:51:21,528 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2014-10-29 22:51:21,625 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2014-10-29 22:51:21,726 INFO  [FeedUpdaterThread] Finished looking for online resources information
2014-10-29 22:51:21,826 INFO  [PluginCompilerThread] Finished looking for plugins
2014-10-29 22:51:21,930 INFO  [SearchManager] Starting up search engine
2014-10-29 22:51:22,383 INFO  [SearchIndexer] Closing search index writer
2014-10-29 22:51:22,384 INFO  [WebServer] WebServer shutting down
2014-10-29 22:51:22,384 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2014-10-29 22:51:22,384 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2014-10-29 22:51:22,384 INFO  [EventDispatcher] Leaving EventDispatcher
2014-10-29 22:51:22,384 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2014-10-29 22:51:22,385 INFO  [DatabaseManager] Shutting down database
2014-10-29 22:51:22,652 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-10-29 22:51:23,154 INFO  [MediaServer] ------------------------------------------------------------------------
2014-10-29 22:51:23,154 INFO  [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f+)
2014-10-29 22:51:23,154 INFO  [MediaServer] Petr Nejedly 2009-2014
2014-10-29 22:51:23,154 INFO  [MediaServer] http://www.serviio.org
2014-10-29 22:51:23,154 INFO  [MediaServer] Java 1.7.0_45-Oracle Corporation
2014-10-29 22:51:23,154 INFO  [MediaServer] OS Linux amd64 3.11.10-100.fc18.x86_64
2014-10-29 22:51:23,154 INFO  [MediaServer] File encoding: UTF-8
2014-10-29 22:51:23,155 INFO  [MediaServer] Headless mode enabled: true
2014-10-29 22:51:23,155 INFO  [MediaServer] User: root
2014-10-29 22:51:23,155 INFO  [MediaServer] User home dir: /root
2014-10-29 22:51:23,155 INFO  [MediaServer] Temp dir: /tmp
2014-10-29 22:51:23,155 INFO  [MediaServer] ------------------------------------------------------------------------
2014-10-29 22:51:23,227 INFO  [WebServer] Socket buffer set to 65535 bytes
2014-10-29 22:51:23,228 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-10-29 22:51:23,250 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-10-29 22:51:23,250 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-10-29 22:51:23,257 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-10-29 22:51:23,263 INFO  [DatabaseManager] Using DERBY database language
2014-10-29 22:51:24,106 INFO  [MediaServer] ------------------------------------------------------------------------
2014-10-29 22:51:24,107 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2014-10-29 22:51:24,107 INFO  [MediaServer] ------------------------------------------------------------------------
2014-10-29 22:51:24,111 INFO  [Device] Created UPnP Device with UUID: ac6bca49-0394-3bca-9119-8ff7091f474f, bound address: 172.31.115.7
2014-10-29 22:51:24,416 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-10-29 22:51:24,467 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2014-10-29 22:51:24,475 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2014-10-29 22:51:24,478 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2014-10-29 22:51:24,480 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2014-10-29 22:51:24,481 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2014-10-29 22:51:24,487 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2014-10-29 22:51:24,490 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2014-10-29 22:51:24,491 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2014-10-29 22:51:24,491 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2014-10-29 22:51:24,496 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2014-10-29 22:51:24,499 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013)' (id=sony2013)
2014-10-29 22:51:24,501 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2014-10-29 22:51:24,502 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2014-10-29 22:51:24,506 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2014-10-29 22:51:24,507 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2014-10-29 22:51:24,508 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2014-10-29 22:51:24,509 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2014-10-29 22:51:24,513 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2014-10-29 22:51:24,514 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2014-10-29 22:51:24,515 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2014-10-29 22:51:24,516 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2014-10-29 22:51:24,517 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2014-10-29 22:51:24,518 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2014-10-29 22:51:24,519 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2014-10-29 22:51:24,520 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2014-10-29 22:51:24,521 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2014-10-29 22:51:24,523 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2014-10-29 22:51:24,524 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2014-10-29 22:51:24,525 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2014-10-29 22:51:24,527 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2014-10-29 22:51:24,528 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2014-10-29 22:51:24,529 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2014-10-29 22:51:24,530 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2014-10-29 22:51:24,530 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2014-10-29 22:51:24,531 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2014-10-29 22:51:24,532 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2014-10-29 22:51:24,533 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2014-10-29 22:51:24,534 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2014-10-29 22:51:24,538 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2014-10-29 22:51:24,539 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2014-10-29 22:51:24,540 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2014-10-29 22:51:24,541 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2014-10-29 22:51:24,546 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2014-10-29 22:51:24,546 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2014-10-29 22:51:24,548 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2014-10-29 22:51:24,550 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2014-10-29 22:51:24,601 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2014-10-29 22:51:24,603 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2014-10-29 22:51:24,604 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2014-10-29 22:51:24,604 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2014-10-29 22:51:24,605 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2014-10-29 22:51:24,606 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2014-10-29 22:51:24,607 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2014-10-29 22:51:24,607 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2014-10-29 22:51:24,609 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2014-10-29 22:51:24,630 INFO  [PluginCompilerThread] Looking for plugins at /opt/serviio/serviio-1.4.1.2/plugins
2014-10-29 22:51:24,630 INFO  [PluginCompilerThread] Started looking for plugins
2014-10-29 22:51:24,632 INFO  [UpdateChecker] Checking if a new version is available
2014-10-29 22:51:24,658 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version 1.0.8 Copyright (c) 2000-2013 the FFmpeg developers
2014-10-29 22:51:24,658 WARN  [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2014-10-29 22:51:24,676 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2014-10-29 22:51:24,694 INFO  [WebServer] WebServer starting on port 8895
2014-10-29 22:51:24,695 INFO  [Device] Updated bound IP address of Device with UUID: ac6bca49-0394-3bca-9119-8ff7091f474f, bound address: 172.31.115.7
2014-10-29 22:51:24,701 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface em1 (em1) and address 172.31.115.7, timeout = 0
2014-10-29 22:51:24,702 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-10-29 22:51:24,702 INFO  [EventDispatcher] Starting EventDispatcher
2014-10-29 22:51:24,702 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-10-29 22:51:24,705 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2014-10-29 22:51:24,706 INFO  [RendererSearchSender] Searching for Renderer devices
2014-10-29 22:51:50,728 INFO  [FeedUpdaterThread] Started looking for information about online resources
2014-10-29 22:51:50,734 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2014-10-29 22:51:50,739 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2014-10-29 22:51:50,739 INFO  [PlaylistMaintainerThread] Started looking playlist changes
Any ideas here guys? Really lost and very tired, where I'm from it's very late now! :-)
So hopefully I am missing sometthing simple and can be easily fixed.
Thanks in advance!
Luckyfriend222
Post Thu Oct 30, 2014 11:07 am
Re: Device list totally empty
Update:
Not even a clean install fixed it. So now I do not know anymore. Anyone have any ideas???
Post Thu Oct 30, 2014 8:27 pm
Is this the righ IP? 172.31.115.7
And the other devices are on the same submet?
Luckyfriend222
Post Fri Oct 31, 2014 5:25 am
Yes, that was the right IP at the time. In the meantime, I made a clean format, installed an older version of serviio, 1.2.1, but still no luck. It keeps on showing that there is nothing.
All the IP's come from a DHCP server, so yes, they are all on the same subnet. All devices are on Automatic DHCP-configuration.
Luckyfriend222
Post Fri Oct 31, 2014 5:29 am
This morning, woke up, rebooted everything, ensured firewall was disabled, an voila, all of a sudden it started appearing.
Sorry for the trouble!
STILL don't know what was wrong, but anycase! Thanks a lot!
