Panasonic Vierra TX-L32D25E not playing some mkv files
Bauke
Post Mon Nov 17, 2014 10:42 pm
I'm not speaking English normally, so I may not use the language as I should. Excuse me for that.
I installed Serviio on a windows 7 laptop and most of my files (mostly mkv files) do play nice on the Panasonic Vierra TX-L32D25E.
Some mkv files however don't. I can see the files but in front of them is a ! mark. I think I should change the profiles.xml file, but I don't know where and how.
I just hope that someone is using the same TV and is willing to tell me how to play these files (with what profile and the the changes of the profile.xml ( if necessary).
Following is the mediainfo:
Unique ID                                : 8473439297606357348612759227230323544 (0x65FECCFEA10EC596EC8B2464EF80358)
Complete name                            : /media/NAS-Film/Natuurfilms/BBC Earth - Expedition New Guinea  - 1/Expedition New Guinea 1.mkv
File size                                : 5.25 GiB
Duration                                 : 51mn 16s
Overall bit rate                         : 14.7 Mbps
Movie name                               : Expedition New Guinea
Encoded date                             : UTC 2014-06-21 17:26:55
Writing application                      : MakeMKV v1.8.11 linux(x64-release)
Writing library                          : libmakemkv v1.8.11 (1.3.0/1.4.1) x86_64-linux-gnu
Format                                   : VC-1
Format profile                           : Advanced@L3
Codec ID                                 : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint                            : Microsoft
Duration                                 : 51mn 16s
Bit rate                                 : 13.7 Mbps
Height                                   : 1 080 pixels
Frame rate                               : 25.000 fps
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.265
Stream size                              : 4.92 GiB (94%)
Duration                                 : 51mn 16s
Bit rate                                 : 640 Kbps
Stream size                              : 235 MiB (4%)
Title                                    : Stereo
Text
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : The same subtitle format used on BDs/HD-DVDs
Language                                 : Dutch
Menu
00:00:00.000                             : nl:Chapter 00
00:12:55.240                             : nl:Chapter 01
00:18:45.000                             : nl:Chapter 02
00:24:34.000                             : nl:Chapter 03
00:32:42.560                             : nl:Chapter 04
00:40:58.000                             : nl:Chapter 05
00:50:45.920                             : nl:Chapter 06
Thanks in advance!
Bauke
Bauke
Post Tue Nov 18, 2014 5:00 pm
Re: Panasonic Vierra TX-L32D25E not playing some mkv files
Now using profile Panasonic (2010). It plays, but not smoothly.
Is there a way to increase the buffer used for transcoding?
Thanks,
Bauke
Post Thu Nov 20, 2014 11:38 am
What profile were you using before trying the Panasonic 2010.
Try adding:
    <Matches container="matroska" vCodec="vc1" />
under the line
in the Panasonic 2013 profile. Restart your PC after changing profiles.xml
This change will remux your file (rather than transcode it) in all of the Panasonic profiles (except 2010 which always transcodes MKVs). Remuxing is far less processor intensive - which is probably the cause of the stuttering.
Bauke
Post Sun Nov 23, 2014 4:24 pm
Hello DenyAll,
Thanks for your answer.
I tried your solution, but then even the files that did play don't play anymore.
There's no way to force the 2010 profile to remux instead of transcode?
I will try to add the suggested line to the 2010 profile
Post Tue Nov 25, 2014 12:40 pm
Sure - in the Panasonic 2010 profile change the line:
    <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" DAR="16:9">
    to
(remove the bits in red).
Users browsing this forum: Baidu [Spider] and 34 guests
